I am impartial to Grolsch swing tops, or alternatively, corona with lime.
Good result homo, needs more lunch
Hahaha...thanks mang.
You better beat that number... ;)
The rear diff and its single pegging rubbish is gonna have a hard time now!!! I should have set the actuators lower!!! :/
Anyone who doubts the -5 isn't the best low mount set up can read this and EAD
I have to agree with you on that 1 Brett - had a chat with Paul last night & in terms maximising that "bulldog" midrange without the sacrifice of top end power, you can't go past -5s
They pack a serious punch :devil:
Haha. If you're involved Marcus I won't make it to the track... Ill be rotten drunk with some skank dancing on my lap!
Haha... If we were in Jappa then you'd be right but in Qld we'll just be rotten drunk.
One thing I haven't mentioned is the new ECU. This has been in the pipework for a while now. It's called a "Blackbox". Unigroup run one in the their RX7 race car and mine is the first finished unit to go into a GTR. The reasoin I moved away from the plug in link (although this is still a plug in unit) is that I ran out of inputs/outputs. Steveo and I thought for weeks about it and anything we could think of we could have put into it. These figures were done after 9 or 10 power runs. One thing I have noticed is the 'blip blip" of the trottle. It's halarious. Yavuz made me sit in the seat and play with the throttle on the dyno. It's like the engine is hyperactive!!!!
haha!!
At some point Allan (33GTRV) from some shit town up your way is coming down..... I think you should get your arse down here also!
Did you send the email to Hiroyuki?
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
