83747408-BDED-481D-A4E9-C644DF3AA119-142
Picture I took this morning with all the covers on. Still need to order a new radiator shroud though.
Also one of those radiator deflector thingos to cover up the horns and A/C fan etc :)
Stop being a lazy fkr and come pick it up :)
Yeah, ill get there!. Time has not been on my side! Grr.
Question for you Nick. Where is your GT PRO set to? Mines at Medium and it's one aggressive mofo. I may need to back it off a tad.
I need to find an ARC one. Not a fan of homo carbon crap.
I was trying to get an ARC one originally but come across my Alloy one on Ebay randomly! Was already sprayed black too :woot:
Black... The new... Shiney? Lol
I remember when first speaking to Alex @ Plazmaman about 3 years ago and i was ordering the stealth kit and he said that Black was to be the new Chrome :P Its Black Bling!
Id have to check with the boys that installed it, im not too sure
raidator guide
tits on a bull
Not when you are talking about the cosmetic stock looking finish! When you pop the bonnet and look down it look a bit average without it! He has gone so far with the presentation it might as well be finished off properly ;)
question, how does the air get to the air box intake if you block the airs path from the grill with the radiator guide ?
You can see the big gap in mine so it would still flow plenty of air... Although I haven't worked out a snorkel setup for mine as I wasn't clever enough to use a stock airbox :(
Oh yeah, scrap that idea!
Im sure brad at profab would be able to fab one up out of sheet ally and in corporate a funnel to the air intake from the front grill.
Then just paint it or powder coat it the new shiney lol.
:yes:
Mine had a shield/guide but it also had a 100mm hole in the guard with some NACA duct tubbing from under the air filter shield to the front grill, plus there is a heap of air voids around the front headlight to allow air to flow inside the air box if it has a opening on the front side behind the headlights.
No good for the ARC box I believe though, but good for a enclosed pod set up.
LOL, just saying.
Rightio. SO after 2 days of 11ty strings around and under the car, deflection gauges, tape measures, more strings, more measuring and even MORE STRINGS, I have a piece of paper with words and graphs. 7 pages of graphs and jargon that I hardly know what it meant.
From what I CAN gather from it. I will need to purchase a roll centre adjuster setup for the front. the HICAS lockout bar needs to be moved up 10ish mm to help eliminate bump steer in the rear. (Design fault possibly). The shocks will be Bilstien with a PSS9 body - That's where the similarity will end. From then on its all Dejan's specs. His valving, gas, spring and oil combo. People may laugh, but the spring rate in these will be about 20 KG/mm BUT it will be very pleasant on the street. They will be height adjustable and damper adjustable.
A little bit of testing and these will be available for R33 GTR's as a bolt in kit.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
