Lol. Here we go. Whore thread ahoy!
Sorry, didnt mean to start anything, was the first thing that came to my mind. Must get out of the gutter lol.
Out of curiosity, how do you expect the new dampers to compare to something like the ohlins flag r's?
Haha. I don't care mate. Whore away :D
Well, I ain't spending all this money for nothing ;).
What I have in there ATM is basically a flag R, just with a Nismo sticker on it. On the canister you see "Ohlins" written on the canister. Time will tell.
If you dont mind me asking, how much are they charging to do the setup for you? PM me if you like.
Just interested as ive been looking at flag r's or r tunes for my 32R, but if these are just as good or better at a fraction of the cost, it may also be a viable option for me as well.
Staying with remote reservoir?
Me reservoir. The body of the shock is a bilstien PSS9 with Dejan's specs.
My set won't be able to be put into a R32. Totally different suspension setup. How much are you looking at spending? These definately are not "budget" but they're not $10,000 either.
Ill pm you more info.
Yeah, judging by your comments i assumed you used to have (well still have for now) nismo r-tunes, which have a remote reservoir.
I know that R32 and R33 GTR's have a different setup, different weight and geometry, which is why yours would be no good for a 32.
"Budget" is not what im after, and yours is sounding like a good option.
Yeah, please PM me some info if you could, im quite intrigued.
  • Like 1
PM's flicked fellas!
Suspension has been put back till the 31st of July. My box of Ikeya bits still hasn't turned up from Japan.... GRRR!
Yea i think i saw that box at the airport when i was working... :ninja:
Dont know where it could of gone... :whistling:
hahaha
Out of interest is it only the nismo r tune coilovers that have the remote reservoir or do the s tunes as well? Reason I ask is I have some sort of nismo suspension in my 34 at the moment and it has a remote reservoir just not sure exactly what it is
So Nick, it turns out you didn't steal my box of gold parts :D. Roll centre adjuster kit and tie rod ends here. That pretty much completes the underneath of the car. I think the only rubber/plastic bush mount on the car is gearbox mounts and engine mounts. ALL the arms are pillow ball and rear diff bushes are alloy.
F3F6AFC0-90C7-41CF-90E2-17D8D94E27F5-350
Dampers should be at Unigroup by now. Booked in for the 31st.
I think thats the box I threw down the stairs cause it had ur name on it :P
cya on the 31st
Haha. Not sure if it would have made any difference. These things are heavy/solid as hell!
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
