I don't really like 33's that much. But the 33 GTR is such a different beast, i love them! This is an almost perfect example of how to do things right. I have been following for a while and it's all been very interesting, but needs more videos! :P
I have a few, but not too keen on putting "silly" stuff up of on the street. :(
I know.
I have one, just needs to be sorted in black. Same colour is homo!
Make sure you get brake ducts while you're at it.
S2/3 are different, which I'm sure you know.
Can't get much easier than that! haha
Tell me thats not a zip tie of the fuel pump outlet 90deg fitting??? I'll cry if it is :-( aaaaaahhhhhh nnnoooooooo!!!! ha ha ha.
Otherwise, nice pig ;-)
Paul , looking like porn underneath the beast. No flash and sparkle just the goods that make it go round corners like a go-kart and brown stains the passenger seat.
Maybe you should get your arse over to ping pong land for Nismo Festival and I'll hep you get nice new black lip for half of what Nissan cut you a new ring hole charge, plus have a week of non stop drinking and eating sushi of the backs of naked candy girls.
Might be stupid question, but is the reason the exhaust goes back into one pipe and splits off again due to clearance?
Oh and great build by the way, fantastic.
Yeah mang. This exhaust was originally made for the owner of Racepace for his own car years ago. Just don't have the space to fit two 3inch pipes beside the diff.
Thanks mate. Looks really well made too. Again congrats on the build.
