it will help if you clearance a little of the tinwork around the reverse lockout fitting on the LHS of the box as it gets very close to the body. Alternatively, just leave it out and get rid of the whole reverse lockout mechanism. Just need to plug up the whole with the right bolt/fitting ;)
I'm heading out there today. I'll see how they're going. :D
Found this on the LS1 forum:
80-holley_pump_specs_947b5fa4b06a2958c97
http://ls1tech.com/forums/fueling-injection/1792075-max-power-holley-12-1800-a-2.html
Set your base pressure at 43, boost to 30. Flow at the pump will be abouyt 125Gph = 473lt/h = 7.8lt/min.
987A01E1-CE10-4B19-B99B-B682678D1092_zps
1B755DD4-9B0F-4D1B-8779-A44C2076EB34_zps
There is the culprit. The tooth fairy was good, bought me a OS88 instead of a few bucks. Winner!
7A8A23C5-9D2E-4992-9B21-E1DC96C56CC1_zps
A6C4A850-FEB2-43E2-8502-C7AD55D7DAC6_zps
E06771C5-2FB5-49CC-B08E-2AFC66733CAF_zps
R3C
C188B285-6593-41EE-B9BE-E06C3CF3493B_zps
Old and new. Evidence of an exhaust leak on the 5 speed.
9ABF37B3-9592-4A69-8672-8C52A913B821_zps
Modified transfer case.
  • Like 2
Both Nitto 1 and its OS88, and one other R34 that ran a Hollinger up here in Cairns used a custom spec NPC twin plate, setup to handle over 1100hp. Basically what I have in my car, with a different type of spring hub centre. So when you get tired of it, you know where to go. Price was reasonable too.$2920.
Day of nothing yesterday. A sub station up the road went up in smoke and the whale was up on the hoist higher than the gearbox jack could reach. Lol.
Took back my old transfer case to Award as it was on exchange basis. Awesome guys at Award, Trish and Terry. Highly recommended!!
That was that.
Looking at fuel pumps, I found this bad boy.
http://fuelab.com/products/race/prodigy-fuel-pumps/item/42402_prodigy_fuel_pump_high_power_efi_in_line/
720L/hour at 3 bar and 560 ish at 75 psi. I'm sick of dicking around with 044's that just don't last. It will also cover me for any future turbo changes/upgrades... *cough* :D. It's E85 friendly also.
That was that.
Pump looks the works, know anyone that have used them ?
Glad to see you are looking ahead, if you decided to change your turbo, what do you have in mind. I thought your car was pretty well balanced as it is but maybe a new age Turbo could make it even better :)
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
