Man I'm honestly thinking about getting it. What are your thoughts? Mine is a weekend warrior...and it's apparently not much more money than an R34 conversion.
What parts came with it? What else is needed? Will my nismo super coppermix twin plate clutch work or do I HAVE to swap to the OS giken unit?
Also do you need to run your stock transfer case or do they include one?
I think we are going to be similar power levels.
AWESOME video car looks super fun.
It definitely changes the car from the tall geared OS 5 speed that I had in it. "Woke it up" as such.
You don't need to run the OS clutches, but it takes out one less headache when putting it all together. I looked into trying to salvage the coppermix as they really are THE clutch to have in a road going GTR. (Mine was in there since 2005 with no service/rebuild at all). It was all too hard. For starters the coppermix was a pull type, this box only has the bosses for a push type, then there was the bigger input shaft issue. The R3C is awesome, much better than expected and NOT how I remember the R3C in other cars I've driven. The pickup/friction point is quite low compared to the Coppermix which takes a bit of time to get used to. Apparently this is the new type. What they have changed, I'm not sure.
You will need to supply your own transfer case.
There are 4 gear options available. I went option 2. Assuming a 265/35x18 tyre and spinning to 8000 rpm each gear will go to
82
118
160
200
234 (same as stock as its 1:1)
310 (same as a factory 5 speed as its 0.757)
You're basically slotting an extra gear in before the 4th gear in a factory 5 speed box. If that makes sense.
With the box, I bought;
Box itself
Modified cross member
Bent shifter
Clutch
Release bearing
Clutch aligning tool
There is a bit of crashing and banging at low rpm, but that's just me not getting the timing 100%. I've only driven 60 kms or so with it so still very much a noob. Up high and drive it like its stolen, smooth as silk. Just slides into the next gear, you don't feel anything through the shifter. As quickly as you can pull back on the gear stick its in. I've found preloading the stick before you lift seems to work well too. I'm still clutching in ATM but as time goes on I'm sure I'll be able to do the no clutch/ lift throttle technique. I'm obviously not tuning a strain gauge - yet. I wouldn't like to daily drive it but for a weekend car it's great!
  • Like 1
Pretty much down the M4 and down Woodville Road at 6 ish PM. (I think you're a Sydney guy so you'll know what I'm talking about). It's all about timing. Going up is down a gear is tricky. The best way I have found is if you're in 4th basically stay in that gear till you come to the lights. As the revs drop to 1000 RPM just push the lever up a few times to either 1 or N depending on what the traffic is doing. No crunching or banging at all.
So much awesome
When you taking me for a spin
When I get this fuel system sorted. Not long after that video was taken it clogged the baskets up again. Full fuel system pull down required.
Damn that shit sucks man
You going to pull the tank out too or just flush it
The tank seems fine.
Not sure where it's coming from but it's fine enough to sneak through 23 micron filters.
6 micron filters are on order and changing ALL the lines. It's just not worth it.
Sounds like fun, as soon as you have driven it for a while the muscle memory will kick in.
This should shave a few seconds off your times :yes:
Nice legs :wub:
Fingers crossed that sorts it
Check the surge see if it's not the issue
I'm from Brisbane Qld, sorry for the question as I haven't read my os giken booklet. But once you engage reverse by pulling the lever up do you have to put the lever up again to go back to neutral or do you just push the lever down as you would when engage the next gears?
  • Like 1
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
