Stroker, vcam, efr, os box [emoji389][emoji385][emoji384][emoji387][emoji386][emoji383][emoji388]
You only live once, I say spend it all now while you can enjoy it
Lol. Hasn't all happened in a week though. Owned the car 9 years this year. Better be worth it!!!
Lol.
It ain't getting done yet. Want a back to back between "GT series and single"... For science. Lol
Excellent
Then do some track work ( 1/4 mile and laps times please)
Then do it again with the v cam ( I think drag times would show f all difference I am mainly interested in the lap time difference )
Proper back to back would be excellent
  • Like 1
I agree. V cam on the strip would make no difference whatsoever.
Just want it driving again. ARGH!
By all means Pete, once it's done, take it for a lap and see what you think. Be good to have some feedback too!
  • Like 1
Hey Paul
I am so tempted to get V can myself. But can you explain a few things for me:
1, What influences your choice of HKS step 1,2 and Pro kit?
2, how do you check valve clearance for VCam to operate? Do you have to machine the Piston recess to get valve clearance?
If I am running 272 Step 2 HKS intake cams already, does that mean piston recess would have been machined in already?
Sorry about these stupid questions as I am still learning.
Thanks
Matt
Awesome build, always love seeing the updates. Heres a pic inside my hks type r cooler just for comparison to the others for those interested.
data:image/gif;base64,R0lGODlhCAAKAIABAAAAAP///yH5BAEAAAEALAAAAAAIAAoAAAISTIBmoLy9XDqyxktfkuo05AQFADs= image.jpg
Ok so I will put up my ARC core for comparison as well :)
Just for Paulie ?
  • Like 3
Just for Paulie
Thank you all for the pics of the insides. I REALLY like that Hypertune and the ARC after seeing them. ARC will be what I order next.
Thanks.
  • Like 1
Hey Paul
Thanks
Matt
Matty,
Your 272's would be 10.2 mm of lift so they would of had to relieve the head for the lobe to spin. As for the piston, im not 100% sure when that needs to be done. My last engne was running Tomei 270 @ 10.25 mm cams and the pistons were not relieved. Ask Chris (if he is doing the work) to pop a plug out and have a look.
Step 1,2 and Pro.
Step 1 moves 30 degrees and uses a 248 @ 8.6 mm cam. You can run that with stock pistons. Dan (Silver Nur) ran this kit on his engine.
Step 2 moves 50 degrees and uses a 264 @ 8.7 mm cam. You need to have pistons relieved for this kit. Step 1 and 2 are the same price.
Pro moves 50 degrees also and uses a 264 @ 10.0 mm cam. Like step 2 you need valve relieved pistons. This kit is expensive because it comes with an ECU which you pretty much chuck in the bin (You wouldnt use it). Unfortunately you can't buy the Pro kit without the ECU.
Here is Dan's result using the Baby step one on his 2.6/2530 setup. vcam_zpsc8bc4718.jpg
Extra 50% torque (300 nm vs 450 nm) at 4000 RPM.
What setup did you use on your Nur? I can't remember now.
I chose step 2 because it was no more expensive than the step one but i'm going to try and use my current intake cam I have in the car at the moment. It cant be too hard, its just a bit of machining.
  • Like 1
Matty,
Step 1,2 and Pro.
Great results! I wonder what the increase in fuel mileage is on these setups?
Also step 2 is on sale on rhdjapan.com looks like substantial savings over the others. I did have my head machined and have valve-relieved pistons. Damnit you make me spend money!! Anyone want some brand new poncam A's?!
You just missed out on the free exhaust cam they threw in when you buy any v cam kit. Makes it even cheaper :D.
Fuel economy? Pfft. Who cares lol.
It's an American thing, some of them won't run e85 because of "bad mileage".
When are you hoping to pick your car up and do a tune?
Car is in a mates garage ATM. This weekend with any luck I'll take it out to where the exhaust is getting done and continue that. Put the front bar back on and start doing all the braided lines and fittings. Not looking forward to buying that stuff. Hate that shop!!!!
Tune? When ever it's done I suppose. Who knows when that will be.
Vcam setups work best on the street, make the engine feel bigger due to more low/midrange torque (cylinder pressure).
My 2.8 now has VCT setup (otomoto kit) and it's great, makes -5's feel like -9's, but you keep the -5's top end :)
If anyone cares: Intake 260deg 9.15mm lift, 0-20 deg sweep (NEO cam actuator), exhaust 252deg 9.7mm lift.
Piggaz' setup will be epic for a 'street car' heheh.
  • Like 3
I won't run E85 because I work in the OIL FIELD not the CORN FIELDS. :)
But honestly the only E85 station is an hour away one way. I'd have to fill drums up and truck it here to store...which I'm not 100% sure is legal without certain permits.
Dang missed the free exhaust cam :(
Oh well next time I guess. I have bigger issues worried about my stock transmission living through the current Torque and HP expectations so I should probably invest in beefing up the trans before adding more torque!
At this point, I just want to hear my car run!
  • Like 1
Thanks Paul for explanation
How does the Otomoto kit compares to the HKS VCam?
I prefer stock look of Otomoto kit.
Any opinions?
I suppose in theory the Vcam would be the superior product as it is variable (not on and off like the Nissan VCT) and swings further. I don't know if anyone has done a back to back between both systems.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
