Why couldn't they have just moved from the VL to the XR6 turbo and be happy with them.
venetians and remove front shafts. then 2 speed powerglide.
Because you are not Lebanese?
Oh I went there.
Ha ha ha. You guys.
Funny
On this topic, just a question, aren't the guys in Queensland still the record holders for the fastest GTR with 4wd, a 26, and H pattern? 7s from memory.
Don't get me wrong I love an angry Rb big cams, laggy single and a H pattern box doing 9's.
This smoothed engine bays and auto conversions not so much.
Me too. Just have no love for the 2wd auto conversion. Just get a normal skyline or falcommodore if you want to do that. Edited by XGTRX
The auto conversions are still 4WD, each to their own, I don't mind dragging to see what improvement the latest mods have made and for some shits and giggles but track is life
Come on Piggy get this thing finished already, there are tracks that need tearing up
data:image/gif;base64,R0lGODlhCAAKAIABAAAAAP///yH5BAEAAAEALAAAAAAIAAoAAAISTIBmoLy9XDqyxktfkuo05AQFADs= image.jpeg
Saw this run 10s today, vnice 34!
  • 2 months later...
Time for an update.
due to time constraints and the ever looming beer bottle, the car got taken to Grim Performance at Hornsby to get the exhaust done amongst a whole heap of other stuff.
- Exhaust completed.
- Individual EGT on manifold.
- Post turbine EGT
- Exhaust gas pressure sensor
- Pressure and temp pre and post compressor.
- Rear subframe has been out. All bushes have been replaced including diff bushes.
- Nismo GT Pro diff has been turned down to soft. Cranky unit!
- New steering race has gone in. Car slipped off a jack and busted a nob off.
To be done.
- Install and plumb fuel system with -10 Teflon braid lines.
- ECU change. Blackbox is gone, Emtron KV8 going in.
- Airbox.
- Strain gauge for sequential.
- Install V cam.
- Tune.
Ive had the Step 2 264 at 8.7 mm cam (WTF am I gonna do with a fairy penguin 8.7mm of lift) reground to something that's a bit more aggressive. Not sure of the exact grind yet but I will know soon enough. Something around 265-270 with 10.2-10.4 mm of lift.
A16A99FC-0DAF-4D17-873F-118EB0AF9872_zps
Dump pipe.
087CB4AE-9EB9-4E77-A349-4159252E74C3_zps
Mid muffler section.
33081E8A-151A-4BB5-A9BC-2BEC30E3F232_zps
Rear diff section.
675DB7AA-9981-4C63-A02C-EFC6E17DB3B8_zps
Gate merge. This photo looks funny. The merge looks very sharp but it isn't really. Must be the lighting.
6BC357F7-2A02-4F89-B59C-C8846866E33C_zps
DEE3FA94-F578-4007-BC00-40C077AE5891_zps
  • Like 7
Reason for this?
Will it chirp second?
I said jokingly "is there anything else you'd like to measure."
that was the answer. It's all got to do with measuring what the turbo is doing.
58 minutes ago, Piggaz said:
To be done.
- Airbox.
- Install V cam.
- Tune.
Getting the notification that this thread had new posts feels like a fun and rare experience now, funny as I've probably been following it for YEARS and Piggaz was a nameless face that I'd never seen in Ozziland.  Now it's a car and a person I know and there is more appreciation for the epic research, thought, development, alcohol consumed, hangovers, work, BBQs and alcohol consumed involved in getting it to this stage that it's particularly exciting seeing it get to this stage.  Very excited to see it getting near being ready to run again!
PS.  You shouldn't ask questions you may regret if they're answered :P
  • Like 2
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
