Why couldn't they have just moved from the VL to the XR6 turbo and be happy with them.
venetians and remove front shafts. then 2 speed powerglide.
Because you are not Lebanese?
Oh I went there.
Ha ha ha. You guys.
Funny
On this topic, just a question, aren't the guys in Queensland still the record holders for the fastest GTR with 4wd, a 26, and H pattern? 7s from memory.
Don't get me wrong I love an angry Rb big cams, laggy single and a H pattern box doing 9's.
This smoothed engine bays and auto conversions not so much.
Me too. Just have no love for the 2wd auto conversion. Just get a normal skyline or falcommodore if you want to do that. Edited by XGTRX
The auto conversions are still 4WD, each to their own, I don't mind dragging to see what improvement the latest mods have made and for some shits and giggles but track is life
Come on Piggy get this thing finished already, there are tracks that need tearing up
data:image/gif;base64,R0lGODlhCAAKAIABAAAAAP///yH5BAEAAAEALAAAAAAIAAoAAAISTIBmoLy9XDqyxktfkuo05AQFADs= image.jpeg
Saw this run 10s today, vnice 34!
  • 2 months later...
Time for an update.
due to time constraints and the ever looming beer bottle, the car got taken to Grim Performance at Hornsby to get the exhaust done amongst a whole heap of other stuff.
- Exhaust completed.
- Individual EGT on manifold.
- Post turbine EGT
- Exhaust gas pressure sensor
- Pressure and temp pre and post compressor.
- Rear subframe has been out. All bushes have been replaced including diff bushes.
- Nismo GT Pro diff has been turned down to soft. Cranky unit!
- New steering race has gone in. Car slipped off a jack and busted a nob off.
To be done.
- Install and plumb fuel system with -10 Teflon braid lines.
- ECU change. Blackbox is gone, Emtron KV8 going in.
- Airbox.
- Strain gauge for sequential.
- Install V cam.
- Tune.
Ive had the Step 2 264 at 8.7 mm cam (WTF am I gonna do with a fairy penguin 8.7mm of lift) reground to something that's a bit more aggressive. Not sure of the exact grind yet but I will know soon enough. Something around 265-270 with 10.2-10.4 mm of lift.
A16A99FC-0DAF-4D17-873F-118EB0AF9872_zps
Dump pipe.
087CB4AE-9EB9-4E77-A349-4159252E74C3_zps
Mid muffler section.
33081E8A-151A-4BB5-A9BC-2BEC30E3F232_zps
Rear diff section.
675DB7AA-9981-4C63-A02C-EFC6E17DB3B8_zps
Gate merge. This photo looks funny. The merge looks very sharp but it isn't really. Must be the lighting.
6BC357F7-2A02-4F89-B59C-C8846866E33C_zps
DEE3FA94-F578-4007-BC00-40C077AE5891_zps
  • Like 7
Reason for this?
Will it chirp second?
I said jokingly "is there anything else you'd like to measure."
that was the answer. It's all got to do with measuring what the turbo is doing.
58 minutes ago, Piggaz said:
To be done.
- Airbox.
- Install V cam.
- Tune.
Getting the notification that this thread had new posts feels like a fun and rare experience now, funny as I've probably been following it for YEARS and Piggaz was a nameless face that I'd never seen in Ozziland.  Now it's a car and a person I know and there is more appreciation for the epic research, thought, development, alcohol consumed, hangovers, work, BBQs and alcohol consumed involved in getting it to this stage that it's particularly exciting seeing it get to this stage.  Very excited to see it getting near being ready to run again!
PS.  You shouldn't ask questions you may regret if they're answered :P
  • Like 2
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
