52 minutes ago, r32-25t said:
This all started cause a gearbox broke,
I think it was actually 4 but that's in the past and right now if I want to drive mine I go to the garage and turn the key :)
And when yours wasn't running, I could have wandered out the back, pushed the boat out and rip skidz too. Your car was off the road for a similar time wasn't it? ?
The car was pulled off the road running. I could have whacked a stock box in it, replace the turbo and it would have running within a couple weeks.
Can't remember it was a few years though  was about the same time you broke your engine I think
3 minutes ago, ActionDan said:
Ok ladies simmer down.
Time to start taking bets on the power figure.
Apparently 480 AWKW was the most power out of a 8374 awkw (out of an Evo) Scott has seen on his dyno.
Nick (3.0/8374) went 461, 24 psi
Pete (3.2/vcam/8374) went 457awkw, 25 psi tapering back to 21 psi (120,000 turbine speed).
I don't know. It's all dictated by that magic 127,000 RPM turbine speed. What will be more interesting will be the boost level that it'll need to get there. Going off the -5 setup, it went 441 at 19 psi. Realistically, I should have just left it there.  Boost level I'm gonna peg at no more then 25 psi, tapering back down.
i know another evo making 450kw 8374 .92 internal gate at 36 psi
why stop at 25 psi
why stop at 25 psi
Because of turbine speed.
127k max. If it reaches that, the turbo is done, irrespective of pressure.
Its no secret that these things have certain parameters to keep within, just like any mechanical part.
What speed are you at with your 30 or 32 psi?
and you know 25 = 127k?
is it to keep them alive or are you saying it wont anymore power beyond 127k
i was about to turn mine up to 34psi haha
No I don't know 25 psi will equal 127K. It was an educated guess... I could be well off. We will know because the speed sensor will be going back to the ecu.
Hopefully the wheel doesn't end up out the back of the exhaust. You're bloody crazy to turn it up that much without knowing what it's spinning at. Not the turbo's fault it if fails.
