4 minutes ago, ActionDan said:
See what I mean, too scared to even call lol
Scott prefers emails because it's quick and to the point.
Whatever. Just do it correctly and neatly. I don't care how long it takes.
Never.
Micks got a 6266 that I keep banging my toe on every Saturday night. It'll be in the bin soon if someone doesn't buy it. Can't give it away!
I could also use it to pretty up my GT500 Block coffee table [emoji23]
