52 minutes ago, r32-25t said:
This all started cause a gearbox broke,
I think it was actually 4 but that's in the past and right now if I want to drive mine I go to the garage and turn the key :)
And when yours wasn't running, I could have wandered out the back, pushed the boat out and rip skidz too. Your car was off the road for a similar time wasn't it? ?
The car was pulled off the road running. I could have whacked a stock box in it, replace the turbo and it would have running within a couple weeks.
Can't remember it was a few years though  was about the same time you broke your engine I think
3 minutes ago, ActionDan said:
Ok ladies simmer down.
Time to start taking bets on the power figure.
Apparently 480 AWKW was the most power out of a 8374 awkw (out of an Evo) Scott has seen on his dyno.
Nick (3.0/8374) went 461, 24 psi
Pete (3.2/vcam/8374) went 457awkw, 25 psi tapering back to 21 psi (120,000 turbine speed).
I don't know. It's all dictated by that magic 127,000 RPM turbine speed. What will be more interesting will be the boost level that it'll need to get there. Going off the -5 setup, it went 441 at 19 psi. Realistically, I should have just left it there.  Boost level I'm gonna peg at no more then 25 psi, tapering back down.
i know another evo making 450kw 8374 .92 internal gate at 36 psi
why stop at 25 psi
why stop at 25 psi
Because of turbine speed.
127k max. If it reaches that, the turbo is done, irrespective of pressure.
Its no secret that these things have certain parameters to keep within, just like any mechanical part.
What speed are you at with your 30 or 32 psi?
and you know 25 = 127k?
is it to keep them alive or are you saying it wont anymore power beyond 127k
i was about to turn mine up to 34psi haha
No I don't know 25 psi will equal 127K. It was an educated guess... I could be well off. We will know because the speed sensor will be going back to the ecu.
Hopefully the wheel doesn't end up out the back of the exhaust. You're bloody crazy to turn it up that much without knowing what it's spinning at. Not the turbo's fault it if fails.
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
