Geez mate, now your testing my memory, lol.
I think initially I had to go digging up top like you, near the high mount stop light. I ran a wire down the passenger side & in behind the side panel where my TV tuner is. I used this to power the reverse camera as well as switch the display input.
Then, more recently, I connected into this same wire for the Pin55 reset, so didn't actually see the reverse light wire as such. I could look at the manual to see what colour it should be, but pretty easy for you to test it by probing it with a pin.
Hey guys I might have a solution that's a bit easier than running wire from rear camera. I only did the brake wire cut today so ill have to wait till the engine light comes on to test it properly.
Months back I installed some LED strips to light the footwells and I powered them from the key barrel ring light which must be triggered by door switch/module. I haven't got my multimeter on me but I'm pretty sure it's a 12v feed as the lights needed that supply, so I was thinking piggy back that wire to the pink/blue brake ecu side and every time I'm chucking the kids in the car/loading groceries/driving with my doors open, that should reset the light automatically. And it's easy to run just across bottom of dash.
So ill wait till warning comes on to see if it will work and will post results. Cheers mates.
Hey Dave, sounds perfect since you've already found that wire.
Of course that will preclude you from launching with the door open for that fully sic Youtube video :w00t:
  • Like 1
Hi all,
Got to test out my setup today, ECL came on in morning and I hooked the wire up to my interior light circuit to see what would happen. Light cleared after about 3 seconds, happy as.
So to anyone wanting a relatively easy way to do this mod and make it automatically reset itself, carry out the following:
Run a wire from the positive side of the ignition key light (ring) - easy to access just pull off a few trims, run it down behind stereo area (straightened coat hanger helps to feed through) across under glovebox to ecu side pink/blue wire.
Job done.
*NOTE: This mod will only work successfully if you occasionally have your car running with the doors open. Also it may still bring the light on over long distance drives, so not perfect but just another way of doing things. Cheers!
    • If you are Ecutek tuned then these TCU tunes are anywhere from $550 to $700 usd. If you are not ECUTEK tuned, then it gets costly!
