Hey guys,
Quick question as no clutch shop will give me a straight answer...
Im after a new clutch for my R34 GT-T, Currently modded with FMIC, BOV, Pod filter, full 3' exhaust, and my Shiney new eboost street :D.
Im looking to get it tuned as soon as i have the clutch installed with a nistune, First Question is Which clutch do i buy?? all shops ive been to say what is the torque of your car, Problem being, i dont know untill i get a tune, and i cant get a tune till i have a clutch!
2nd question, Before the tune, Are there any other supporting mods i should look into as to make the tune more economical/beneficial? ive heard Z32, Fuel pump, Coil packs. But not sure what can be overlooked and installed later, or what needs to be installed for the tune.
Any advice or opinions greatly appreciated, Cheers guys!
Edited by EuphXP
https://www.sau.com.au/forums/topic/398503-which-clutch-s/
I am running an Exedy cushioned button clutch, happy with the way it drives and feels....price was a bit of a kick in the teeth though.....
Cant remember what they are rated too, i think it was a tad over 300kw so it should be more than enough for your needs...
https://www.sau.com.au/forums/topic/398503-which-clutch-s/#findComment-6328715
In regards to which clutch you should buy it is basically a question of do you have any future plans for more power or what is your future power goal and get a clutch to suit that. But with the setup listed something like a heavy duty exedy clutch for a few 100 will be more than enough. For the other mods youve listed coilpacks only need to be done if your ones are stuffed and z32 wouldnt really be needed until you probably do your turbo and start pushing more power where your stock afm is at its limits but the fuel pump would be worth replacing if you want to do it for piece of mind but again for that setup you listed not essential.
https://www.sau.com.au/forums/topic/398503-which-clutch-s/#findComment-6328719
Wasnt looking to spend an arm and a leg, and as for future mods, im only aiming for ~250awkw for the time being,
Ive got 2k set aside for my clutch installed, and have been quoted for the nistune installed and tuned for $1100.
Was just going to use my local mechanic for the clutch install, just need to know which clutch to throw in it...
Ive had a look at the exedy clutch kits, as with the NPC Kits and was quoted for a heavy duty organic clutch kit. $753.50. My mechanic said he would rather work with exedy as he has contacts.
If i was to go exedy, which clutch kit do i go? Heavy duty? Button? Ceramic?
And as for the flywheel, ive heard with ceramic clutches its best to get a new flywheel to improve the life of the clutch, ive also heard that theres no need to do flywheel >.<
https://www.sau.com.au/forums/topic/398503-which-clutch-s/#findComment-6328787
you should never put a lightweight flywheel in a street car... totally goes against anything streetable
it's come with the clutch. this one-> http://www.nismo.co.jp/en/products/competition/clutch/sckit.html
so npc organic clutch will be better than this one for street use?
Cheers!
https://www.sau.com.au/forums/topic/398503-which-clutch-s/#findComment-6329664
Npc also do a 10" organic clutch which is rated to 280 rwkw. Jap__star on here has one and pushing 300 rwkw. Very driveable and would be perfect for a street car.
We regularly put these in cars making 300rwkw without issues. They can hold a lot more torque than we give them credit for and being a pull type clutch, they will hold more torque than their push type counterpart.
would the carbotic 10" handle 325rwkw...?
We've tested them to 600rwhp, drag racing 9k GTR launches, track work for years. They will eventually wear out if abused or not driven correctly. It's usually the latter that gets most people on their first button clutch
which one is better for street use?
nismo clutch kit(the basic one with lightweight fly wheel that one) or npc organic clutch?
I would highly recommend the NPC Organic 10". Have fitted them to many cars. Get nothing but rave reviews from each person every time. Be careful over 400hp though, we don't often push them harder than that so how far they will go is still relatively unknown
https://www.sau.com.au/forums/topic/398503-which-clutch-s/#findComment-6329751
I have had both a Organic NPC and a Bigmouth track NPC button.
The organic is better for every day use, I was pushing 450hp when my GTR was my daily and not an issue what so ever until of course wear took place. I was doing 6500-7000rpm launches getting my 1/4mile time down to a 12.385 at 111mph when I decided the clutch had enough it was slipping at the top end of my gears mainly second and 3rd.
I asked MANY MANY suggestions on which way to go after killing the organic. Dan(ERD), Noel(Fineline), Strik3r, Hyped6 and Strudel.
A majority suggested the Bigmouth track, and I am glad I listened to them. The clutch is a little adsertive and obviously doesn't like being ridden like a button clutch shouldn't be, but in traffic somewhat difficult to avoid. but 1 of the best things I had in my GTR. Not as piggy as some of the button clutches I have driven and VERY liveable.
My clutch is still holding out and I don't expect having to upgrade for a long long time, so It's my recomendation.
https://www.sau.com.au/forums/topic/398503-which-clutch-s/#findComment-6330070
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
