I use mine every 3rd night? not too bad. I just drop it at around 1700rpm, I don't bother driving it smooth (clutch will last longer). Up the car park ramp at my gym is gold, there's a speed hump midway up. I usually just handbrake then chirp it over, people think I am retarded.
Because race car :P
Sweet, thanks guys! More parts i didnt budget for...... Car has done 1500kms since tune and has killed coilovers and clutch so far, what next? (Nobody answer that, Flamin Mongrels) lol
done a few thousand on my Carbotic now Mat..2 track days..
Its no pig its a dream to drive man, you won't be disappointed at all
unless you prefer grumpy old man clutches...why anyone would want one or one of those crappy rattly metal things is beyond me.
.The NPC is all class
Its a dream to drive man you won't be disappointed at all
.The NPC is all class :D
Ah sweet! Thanks for that :D
Has it still got a good pedal feel etc? Apparently he said mine will be modified as ill aim for 400kw eventually.... :yes:
I slip my 10' NPC every time I take off, I know its not the best for the clutch but I'm 2 years in and its still showing no signs of slipping.
There a quality product thats for sure. I'll have a look at mine when the engine comes out of my car in the last half of this year.
Can always send it back for a rebuild anyway
I also did some calling around apparently confusing ppl when i called after matt had lol .... but i have the silver plated excedy comp clutch abd jim berry said its a good bit of gear and he can build it to handle 450kw + with a 10" or bigger something and solid centre carbon thingo ?? sounds good he built my mates cusco hyper angle and its amazing and handles all the clutch kicking he can thor at it withh 300 odd kw so might go down that path
LOL, i spoke to Jim for nearly 2 hours yesterday man!
He said they will be a pretty tough bit of gear, mine will be different specs to yours though as ill be on the road more than track :P
I got that Exedy Silver NC10T push pressure plate from a R32 GT-R if you want it, it's 1.1 tonnes
Problem is your GT-t is Pull not Push, unless you want to convert it to a push setup. Cheaper in the end.
  • 1 year later...
#strongbump
So yeah, I've had my NPC clutch for nearly 2 years, about 15 000 km & 3 track days..
It's starting to slip!
In 4th when you mash the pedal it will slip a little/shudder then bite & my friction point is quite high up. It engages in the last 1cm or so.
I think it's dead, maybe my mates have ridden it to death :(
How long has your NPC carbotic lasted?
I pulled my NPC when I did my engine change out. decided to get it rebuilt rather then having to pull the gearbox out later on if it started slipping. Have to say, the clutch looked great, no marks/hot spots etc on the flywheel or pressure plate and the friction material, besides being worn, looked great. Best looking clutch I've ever pulled out of a car. Could have gone back in but was running low on friction material so thought I'd start fresh
They were very helpful and quick rebuilding the clutch to. Sent it away Thursday I think, had it back on Tuesday or wednesday.
#strongbump
Mine should have been similar in design i guess and after 5000km it also looked brand new... I would go with Callans suggestion and just get a freshen up, its just new pads and a quick clean up most likely... Could be other causes for the premature wear though not necessarily the clutch itself, grease or oil contaminating it etc... Only way to know is to pull it out and have a squizz!
I ran 255rwkw for pretty much the whole time I had the clutch in, and I daily drive it and slip it on the street a fair bit. So I'd say if the wear on mine was excessive then it was to be expected. I dont think it was terribly worn but, should have measured how much material was left and compared to new.
The rebuild is basically a complete new clutch. The pressure plate I think was brand new and they just removed and replaced the pads on the clutch plate, must have checked the springs etc and the spline as well but this wasnt replaced (all looked good when I pulled it out so not suprised)
All up it cost me just shy of $500 with a new throwout bearing and express delivery, so while thats not 'cheap' its not to bad for a new clutch considering new ones are up near $800 now I think?
This is all my NPC gear reconditioned:
Edited by 89CAL
I'm just a little concerned about the premature wear, especially my car isn't make more than 200kW
Might pull out the box next weekend whilst I fit the new turbo :)
Yep good plan! There is no way its power related and it shouldnt wear that quick unless its been driven like shit...
Pull it out and report your findings :P
#strongbump
Just copper mix it and be done with it. If you did it in the first place you would have to pull the box out again! :P
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
