im gunna try, i wouldn't even have to take the car of the trailer :)
I've just about got my car ready log booking, but im not sure if it will be done by this date.
can i rock up with a caged, non-booked car?
https://www.sau.com.au/forums/topic/398520-wakie-19-may/#findComment-6333099
cheers, will do.
but before i go bothering them, do you need to be a member of one of the clubs?
Just spoke to Jonathon Graham (WRX guy) and he said as long as the car passes Scruit and you are a member of a CAMS affiliated club (SAUNSW) you are good to go.
You can pay by the link in the entry form, fill in the entry form and email it to Jonathons email address.
If you pay before 11 May cost is $165.
Mark
https://www.sau.com.au/forums/topic/398520-wakie-19-may/#findComment-6338574
  • 3 weeks later...
Did you have the Mines baffles in the 26 covers on?
Yes and it was 99% better, still had a small amount of slatter that got through the covers/baffles and catch can, only a couple of mills/drops though, I didnt drip down from the car to the track but it was still annoying.
To fix the problem Im going to get fabed up another catch tank which will be removeable or have a tap in it to drain it when it gets some in it, even after a full track day I think there would be no more than 10 to 20 mills in it.
The first session I just plodded around and it was fine, the second session I got up it a little bit more and that was fine, the third session I thrashed the bejesus out of it, changing gears when the shift light flashed and trying to keep it on the boil, thats when it spat a little.
Awesome fun day with a PB and big four wheel drifts, the Hankooks although only classed as a street tyre were great, no nasty moments with them at all even when doing four wheel drifts through the corners.
With a few more sessions under my belt I can smell single figures.
Ill fix up the little issue of the oil and give her some maintanance like new pads and stuff and then....
Come on Skyline Nationals.
https://www.sau.com.au/forums/topic/398520-wakie-19-may/#findComment-6362524
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
