Hello Skyline community,
Up for sale are pre loved parts from my R34 GTR.
Nismo AFM x 2
Near new, still in original boxes with japanese instructions. Had them tested at Racepace and are in good working order.
$ 650
R33/R34 GTR Ohlins PCV coilovers
Purchased second hand from Japan. Had them shock dyno tested locally, and driven no more than 1000k in Oz. Fully adjustable- Spring rates are 10k front and 8k rear. These coilovers give supreme handling (even with cheap maxxis tires) however I personally found them to hard for daily use.
$ 1300
R33 GTR Tein type CS coilovers
Purchased second hand from Japan. Have not been used at all in OZ. Great setup for the street and daily drive. Excellent build quality from Tein, very light weight coilovers. Fully adjustable - Sping rates are 4k front and 4k rear. Handling is slightly enhanced over stock VSPEC suspension, and does a good job of soaking up bumps. Compatible with R34 but with specific bump/rebound settings for R33.
$ 1200
R33/R34 GTR Blitz Inductions cover & Filter
Purchased brand new and used for less than 200k's in OZ. A well and truly discontinued line from Blitz. Makes swapping the induction cover on/off a breeze if you want POD like sound.
$ 300
R33/R34 Blitz POD filters and elbows
Second hand in good condition.
$ 250
R33/R34 K&N POD filters and elbows
Filters are band new and never been used.
$ 300
R33/R34 Apexi POD filter kit
Purchased brand new and used for less than 2000k. Great condition, complete with brackets, screws, box and packaging.
$ 250
Stock R34 GTR Turbo's
Done 60,000K, purchased my car stock standard, only mod done was factory boost restrictor removed. Never boosted past 1bar.
$ 800
Apexi PFC Boost Control Kit
Purchased second hand from Japan. Done about 1000k in Aus. I reverted back to stock solenoid to keep a factory appearance.
$ 300
Kuhmo KU36 265/35/18 tires
Great condition, done less than 5000k. Used only on the street and never thrashed. Upgraded to set of Michelin Pilot super sports.
$ 550
R34 GTR Trust Oil Cooler Kit
Purchased second hand from Japan. Never installed it on my car - In good condition, I believe its the model that sits in front of the radiator.
$ 450
RB25/RB26 HKS Ex Cam gear
Still in box, good condition, a few scratches and marks.
$ 120
R34 GTR Ganador Dual Titanium Exhaust
These are as rare as hens teeth! Purchased second hand from Japan, never installed on my car. Still contemplating whether or not to sell. However i'm already running a Single ti Ganador which is also very cool. It has a dint on one of the tips which can be repaired. Upgarage is currently advertising one of these in less condition for 99000yen!
$ 1400
All parts are in Melbourne. I will be happy to send parts interstate at buyers expense. Please post/PM any questions or requests for more photo's.
Cheers,
Chris.
Edited by ChrisR33GTS-T
That's a great price, I guess you will be selling yours before mine go! :) Mine are in great condition, good upgrade for someone with a R32 or R33 => Good luck with your sale!
  • 1 month later...
  • 3 weeks later...
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
    • They are in fact just nozzles. They are there only to produce a spray pattern and limit flow. The injector itself is what I use to control flow to the 7x nozzles. My old system had no injector and only PWM the pump. This lead to a lot of inconsistencies, and poor atomization at low pressure when the pump was ramping up.
