I know, but it's not the same when I don't get to visit her! :)
Every man has his price! :)
At least the Nur has the appropriate 19" LMGT4s back on instead of 20" rims.
If in the Blue Mtns you can drive mine if you're over 30 lol
Coil packs gone, and lenses when I get around to dropping them off.
Turbos still available.
I have a pair of stock R33 GTR turbos off my blue thing sitting in the shed that came off at about 70k when the HKS units went in. No idea what they are worth, but PM me an offer if interested.
Also have a pair of R33 GTR Nismo clear side indicator lens thingies in good nick that can be yours for a measly $30, and a set of R33 GTR Yellowjacket coil packs that have done less than 1000K's work for $200. Think those will also fit some Stageas and S1 R33 GTS-T's from memory, but you would need to check. Again, do the PM thing if keen.
Cheers,
JD
This is true, he's not a collector so never planned to keep it.
Haha sorry, those 20s were perfection on that car in my eyes! Not really a fan of LMGT4s. But hey wheel choice is a personal thing!
And thankyou but I have my own little toy in the garage! I just like viewing rights on others occasionally :D
Hey guys just selling some stuff to clean up the garage contact me on 0410717935 if you want something or pm me on sau. Message me
For photos
So I got a set of low king springs $150
A series one front bumper great condition $100
A series 2 kr4 silver bonnet $150
A 52mm 3 row alluminum radiator eBay job $80
A rb25det block, intake manifold "taking offers"
A cam cover $10 And a exhaust manifold heat shild $10
A fusion wiring kit $15 and 2 x gear knobs $10 each
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
