Another update
Stripping S2 R33 Parts
Prices are negotiable.
Can post or take a car load to Sydney. Located in a Canberra
GTST wing $100
(SOLD) - ECU $150
(SOLD) - Wiring loom $150
Side skirts $100
Rear bar $75
CD player surround $70
(SOLD) - Double din CD/DVD player (alpine) $400
(SOLD) - Shifter surround $40
Centre console $80
Front seats (minor tear on drivers bolster) $150
Rear seats $100
Boot hatch $80
Tail lights $150 (KR4 Silver)
Skyline rear centre garnish $50
Door windows $100 each
Window regs $100 each
Aftermarket cat back exhaust $300
RB20 Turbo (no shaft play about 140,000kms) $200
(SOLD) - G4 Racing Coilovers $400 ono
(SOLD) - Engine $600 (170,000 kms Long block, healthy and strong)
(SOLD) - Diff $200
(SOLD) - Half shafts $100 each
Rear adjustable camber arms $100
19" Maxis Super Hero rims $900 with brand new tyres
19" ROH Modena 3 Piece Rims $1600 with 80% front 50% rear
Turbosmart boost tee $40
Turbosmart boost guage $40
Aftermarket adjustable tie rod ends $70
Stock clutch and flywheel $120
Passenger front guard (perfect condition) $80
Tail shaft $120
Starter motor $100
Alternator $100
Front and rear Brake Calipers $350
Brake rotors x4 - $200
Hubs $300
(SOLD) - Coil packs $150
(D/S SOLD) - Rear Lower control arms $60 each
Rear cradle $50
Front lower control arms $70 each
Seat belts x 4 $150
(SOLD) - Drivers door cards $80
Passenger door card $80
(SOLD) - Drivers side window switch elects $100
Passenger side window switch elects $50
Window switch surrounds $80 each
Side mirrors $90 each
Steering surround $50
AC control unit $80
Window wipers $20 each
Fuel flap $60
Fuel cap $20
Bonnet latch $50
Boot latch $50
Power steering reservoir $150
(SOLD) - TPS $50
Top dash AC vents $20 each
Passenger side headlight $100
Power steering rack $100
CAS $100
VCT Solenoid $70
Turbo Lines $40
ABS Box $200
Manual Conversion (clutch master $80, clutch slave $80, clutch pedal $50, brake pedal $60) or kit for $225
Nissan Prince Foot well carpets x5 $300
Glove box with working latch $50
Fuel Pump $50
Fuel pump cradle $75
Antenna $75
Lock set (steering lock, door locks, boot lock with key) $200
Sway bars front and rear $50 each
Boot carpets and sides $100
Prob more that I have forgotten.
NO FRONT BAR
NO INTERCOOLER or PIPING
NO RB25 TURBO
NO GEARBOX
NO HEADLIGHTS
NO DIFF
Still have the stuff on the list guys if anyone needs anything make me a offer
Fs: cusco rear camber arms for r34 gtt, should also fit s15's. Never used. Looking for $400 neg.
Also have a hicas lock bar, never used $60 neg.
Still got my greedy oil cooler as well $450.attachicon.gif1005209_642792255745479_1108427958_n.jpgattachicon.gif941706_616592388365466_1763377059_n.jpg
will hi cas lock bar fit r33 gtst?
I have an old 32 gtst one.
greasy and unpainted, but a clean and a coat of paint and itll be sweet.
Has inner ball joints but they are a little loose, not too bad.
Only good if it fits.
The driftworks hicas elimination kit is much nicer, no more ball joints, thats what i have.
Edit: no outer ball joints, have to use your own.
Edited by D.I.Y. Mik
JZZ30 Soarer, 1994 Model
230 odd thousand ks
Auto
near standard
has FMIC (HPi Japan) and cat back, standard boost
ACT rego, will put another 3 months on for new buyer
Good honest car, those that know me know if I sell a car with anything wrong with it, I sell it very cheap.
This one is good mechanically
Not long had the front brakes machined and calipers rebuilt
Tyres are good, seats are very good for its age.
Has DVD player in the dash, but I dislike big stereos so its not very loud
Interior has the usual Soarer issues, split tops of door trims, and a couple of holes in the dash where people have mounted gauges in the past.
NO blinky dash issues, toyota had fixed that problem for this model year, and same for the door trims ripping off when closing the door.
Looking for $5k ono and must go because I want a GTR
anymore info PM me for my number or just shoot through some questions
Cheers
Andrew
FOR SALE; R32 M-Spec side skirts and rear pods. I bought these with intensions of fitting them on my R32 but sold the car so I no longer need them. Both items are in black, genuine plastic. Side skirts are perfect condition, passenger side rear pod has a small crack. Take the lot for $250.
For photos msg me @ 0404 727 515
Cheers
I might want to add that when I say 'unit only', I am pretty sure that it includes the valve and power unit too. But not the hoses, clamps and fittings etc.. but I will confirm tonight.
Injectors sold.
Pics attached of the boost controller.
Main parts are included with it, but u will need to byo hoses, clamps or be creative..
Additionally, the following link should take u to the instructional manual http://www.greddy.com/upload/file/profec_bspec2.pdf
Got a few things fot sale
Nismo gear nob
R33 Clear side winkers
17" wheels with good tread
R33 s2 drivers headlight
Details/ pics in link below
http://www.skylinesaustralia.com/forums/topic/429714-r33-parts-and-17-wheels-for-sale/
Seimens Deka 660cc injectors - $250
I bought these 2nd hand from these forums, but I never actually got around to putting them in. The first owner put about 4,000kms on them.
They come with the stock loom with the required plugs soldered on to the fuel rail spacers. So I can only presume that the loom would would only fit a S2 RB25DET NEO. But, not sure if the injectors themselves can be fitted to another loom?
Profec B spec II boost controller - unit only; $120
I thought it was broken, but I realised it wasn't fitted properly and it sat in the shed for awhile.
Happy to send pics, or for you to come around and have a look.
PM or mob:O432808254
Cheers, Karl
Stuff sold.. Thanks guys.
Ross Tuffbond Metal Jacket Harmonic Balancer with idler tensioner kit. This kit fixes the issue of the powersteering belt getting thrown when giving it big revs.
Have put 5000km on the balancer and kit and I am selling due to upgrade to ATI 1000hp balancer.
Came of a R33 GTR.
Chasing $500 ONO. The balancer is $480 from ross and the kit is another $300, so great deal.
Will seperate if someone makes it worth my while.
Pics to come, PM me for further details.
Injectors no fit without extra work
Loom is ok with these but took to tuner and he said nah prefer not to mod to suit :(
(they fit BF fords and a few other ford models)
Apparently though ID's are the same so it can and has been done before.
Nismo gear nob
how much for the gear nob and indicators?
Bummer, Sin. I didn't give u any wrong info did I?
All fine, trying to on sell in FS section with another 2 sets I have accumulated.
Ended up buying new 850cc's - direct fit. :D
They will fit so were good, but about a centre meter to long so requires mods to the fuel rail and maybe caps.
Tuner and me prefer not modding. Just another place leakage can occur.
Being as old as me leakage isn't a good look :P
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
