So getting dicked around by people so selling it again (not so much here)
2x 30m rolls of window tint.
One is 35% tint 1.5m x 30m
The other is 15% Tint 1.5m x 30m
$200 it bought together or $150 each separately.
1997 WRX
121,000kms
1.5 way diff
Apexi and pedders lowered shocks
Hot dog exhaust
Turbo smart BOV
Turbo timer
3x HDI electric guages
Running stock boost
Sound system
Comes with BBS style 18" wheels and a set of stock wheels
Comes with 3-12 months rego depending on sale price
Best daily you can have while having fun on a cheap level.
$6500 or more with 12 months rego
Bren, managed to kill my hazards button over the weekend. Any chance you have one?
hey mate... not sure if you're still after a hazard switch.. i have a couple at home.. only the bulbs in them don't work.. only drama..
PM me if you are interested..
cheers.
Swap: I want to swap my s1 1993 gtst model for a series 2 stock gtst, nothing wrong with my car, it has full cream leather interior as well as cream leather dash, engine is at 96'000 genuine, amg rims, catback, aftermarket intercooler and radiator, looking to see if anyone has a series 2 stock they would trade!
Hi guys, doing a bit of a garage sale to clean out my shed a bit, got some parts leftover from old projects. Parts are located Southside ACT, I'm best contacted by SMS on 0404 303 954, I'm not very frequent on here but I try and check my PMs every so often. More pics available, just give me a buzz. Prices are pickup, happy to post at buyers expense, or deliver for a fee.
RB20/25/30 Engine parts:
- RB20DET silvertop forward facing plenum, deletes idle motor, factory cut n shut style, doesn't come with factory TB or sensors or anything $150
- Plazmaman FF Plenum, to suit RB30, as new unused condition. Comes with cold side cooler pipes, hoses and clamps, to suit XF TB, I paid $1160 new, after $800
- 6x VLT Injectors, 260cc, $150
- Various RB30E Injectors, $5 each
- RB25DET S2 CAS, ignitor, coilpack loom, $50 each
Pics of RB20 plenum:
Thanks guys,
James
hey guys ive still go a few things left over from when i stripped my 33.
hubs $250
intake manifold $150
control arms $50-70
passenger door missing window reg $100
clutch brake pedal plus master cylinders $200
cas $100
tail lights $130
most interior panels
jjr 3" stainless steel cat back exhaust $250
Edited by dd33
hi all i have allo of stuff lying around
serires 1 rb25det loom
intake manifold /turbo intakes
cam angle sensor
cam gaskets with half moon aswell
new water pumo thermo stat
timming belt
many vacum hoses heater hoses and radiator pipes
r32 power steer pump
33 engine mounts
and other hose clamps and shit like that
0431434808
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
