hi guys -
i have a R33 i am parting out with -
already missing is motor gear box tail shaft diff (diff might be for sale) calipers front and back and suspension and steering rack - aer gone - dash is bugged
good point body is straight - bonnet has some hail dints but good other then that (spray job wouldnt hurt) $200 ono
all seats front and back including rails are for sale - offers - all boot linings -
boot and rear wing standard R33 gtst - offers
fuse box in engin bay - no lid $20
has master cylinder and lines as well and handbrak just no calipers
good basic shell if anyone wants it $300
Edited by Reese69
hey guys ive still go a few things left over from when i stripped my 33.
hubs $250
intake manifold $150
control arms $50-70
passenger door missing window reg $100
clutch brake pedal plus master cylinders $200
cas $100
tail lights $130
most interior panels
jjr 3" stainless steel cat back exhaust $250
price up dates
plus some other stuff
intake manifold $50
both rear lower control arms $50
passenger door missing window reg $50
clutch brake pedal plus master cylinders $100
cas $50
tail lights $80
front and rear seats $180
jjr 3" stainless steel cat back exhaust $220
fuel pump $30
passenger side guard $50
stock cat back exhaust $150
stock shocks $150
turbo manifold $50
adjustable front tie rod ends $50
Edited by dd33
Just testing the waters locally for my 1989 R32 GTR
63k km on the dash (not sure if legit, but seemes clean enough)
Very Clean interior, stock GTR seats, dash perfect and uncracked (rare)
Drivers bride brix 1.5
New fully forged engine by chasers motorsports with receipts for most things from previous owner in ViC
<2000 km on the twin 2860-5 turbos
Haltech platnium pro ECU ~ safe tune
Apexi power intake pods
Gates timing belt
Adjustable cam gears
Freshly built head (you can see for yourself the fresh acid dip)
18x9.5 sparco racing wheels
Brand new excedy HDCB Clutch
Walbro 255lph fuel pump
Carbon fibre weathershields
+++ More but id have to go throgh my stacks of receipts!!
1 More month of ACT REGO!!
The setup will easily make well over 300kw with bigger injectors (I have ID1000 injectors ready to go in for extra)
looking for $14k ONO
or $12k ONO with stock ecu and different wheels
Or if you want everything done for the 100k km service it will be 13.5k + whatever your choice of mechanic charges
Why so cheap?
Because....
I beleive it needs a new tensioner pulley
the pulley was making a weird noise one morning and after further investigation the timing belt has a bit of slack.
Ever since discovering this i havent driven the car just to be sure!
i beleive the timing will need to be redone aswell because the CAS was removed to check the belt
Drove like a dream before; most probably will still drive like a dream now, however dont want to risk a possible catastrophe!
it would be safer to say it needs to have the 100,000 km service as a precaution while the whole front cover is off
to have the tensioner bearing (and everything associated) changed before driving anywhere
There is also a minor dent along the drivers side door and rear fender were the front wheel picked up something.
after spending all this money of the engine and personal issues that have come up i cant afford to spend any more on this beast!
i am way too busy atm to do organise a 100k km service. wont be free until february 2014, so the car is up for sale until then !
if you want to view the car give me a text on [removed]
**EOI for some stock 34 gtt parts:
Bonnet
Front Guards
Standard Rear Wing
All parts are factory black, fenders and bonnet in very good condition (will double check for light surface scratches), standard wing's paintwork has seen better days and is fairly faded on the top of the wing blade (will need a respray).
**The following are also up for grabs:
GENUINE Impul gtt front bar
Replica 34 gtr spoiler with carbon wing blade
Impul front bar is a little rough as it had a confrontation with a kangaroo, but won. The paint has cracked and there is very slight frays on the fibreglass around the grill, but otherwise structurally perfect.
Replica spoiler has never been fitted as I'm waiting on carbon wing stands from a group buy on here. The carbon blade is very good quality but the standard wing stands didn't align properly with my boot. It's a dead easy fix, but I haven't been bothered to address it.
If the carbon stands fit properly I may keep it (unless the right price is agreed upon)
I will work out pricing asap, just gauging interest for now.
PM for info and pics
Selling some R32 GTR (RB26DETT) gear off. and a couple of 34 bits as I need cash
New Harmonic Balancer - ATI (Super Damper), - 500HP - $400
  • Eliminates torsional crankshaft vibrations
  • Exceeds SFI 18.1 specs
  • Black zinc chromate finished
  • Tunable, rebuildable, and extremely efficient at ALL RPM
  • Laser engraved 360° timing marks
New OEM Injector Ballast Resistor - $100
New Dspeed smoked indicators - $300
Near New BM57 (ABS) - $300 (couple of hundred KM's)
New SRI Front Upper adjustable control arms - $175
New SRI Cold Air Box Kit for R34 GTT - $140
^good savings^
Used parts in good working order and condition
Denso 720 Injectors - $350
Nismo Oil cap in Packaging - $75 (Brass/Rose in colour)
Steering Rack - $100
Power Steering pump - $100
Starter motor - $100
Front Bar Mesh - $50
Front Seat belts vgc - $150
Cusco Strut Brace (round) - $50
5Zigen JASMA exhaust muffler - oval (axle back) $175. As new.
Professional Custom made Exhaust true 3" cat back with Mid muffler & Oval tail muffler (mandrel bends etc..) under 1000kms no damage - $450
HID's for N1 headlights with globes & ballasts - $100. Fitted and used for a few weeks.
Considering parting with:
- NISMO Blank Keys in packaging - 1 x 8 point, 1 x 10 point. Open to exceptional offers (via PM only).
- New Genuine N1 front bar with OEM Lip and N1 Vents in Original OEM Packaging - $900 (as a package only)
All + Postage.
PM me and I will get back to you.
(more parts may be added so check back)
    • I removed the head expecting to find broken and bent valves, but instead found number 1 at TDC and cylinder 2 at the top of its cylinder stroke as well, thought that was weird and proceeded to push cylinder 2 back down until it either bottomed out on its other piston half or the conrod either way we found the issue kind of,  now to remove the engine and see how the block looks, hopefully its just the top off a piston.
    • A little more work this week.  Fitted astra power steering pump in the boot with a lowe fabrication bracket. Gave the pump a good clean, fitted Anderson plug and high pressure fitting. With the intercooler being flipped under rad support factory headlights weren't going to work. Ordered a set of origin battle lights, they arrived so got them test fitted. Will require some fiddling to fit nice but was an easy quick option for now. And today we pulled out the manual Rb gearbox and test fitted a ZF 8HP50. It will fit with some casting tabs cut off and small tap of the tunnel with a hammer. Pick up the adapter plate Wednesday so hopefully all bolted in Friday and measure for tailshaft which will be a 2 piece. Been doing a lot of ecu, pdm and tcu loom design so when comes to wiring it in a few weeks will all go smoothly.
    • FYP. Sadly. Even bolt cutters wouldn't take 2 sec. But in the days of 18v angle grinders, nothing is safe.
    • One piece driveshaft I would recommend a dual CV setup otherwise stick to OEM. I have heard most one piece driveshafts cause excess vibration otherwise. The transmission grind I'm quite familiar with. You can try shockproof gear oil, otherwise you need a new transmission. The shifter is extremely simple on these cars. If you want pull apart the assembly and replace the plastic bushing but I doubt that fixes anything. The tail light issue is very common, unfortunately new tail lights are long discontinued. The trunk antenna going up always is because your radio doesn't have a true power antenna control, just remote amp power signal. There is a blank switch plate that you can pop out and install a switch for this or alternatively source a head unit that has proper antenna control. Throttle body sticking you have to disambiguate by disconnecting the cable and seeing if the linkages are the problem or something else. There is a procedure to adjust them, refreshing them is also somewhat involved if that's the issue. I have dealt with many of these issues. Old cars really are fractals of problems. The more you fix the more you discover there is to fix.
    • Welp, you've got a long list of experiences right there. I'd say you're on the right path.
