My brother in law hasn't been able to decide so your not too late at all mik
Hmmmm.... cool.
I wonder how i could convert it to 240v 50hz from 3 phase.
New motor maybe, or just a black box of some kind (my electronical knowledge is not too good )
Hmmmm.... cool.
3 phase converter starts at 2300 + G for something that will run up to 3hp
Possible to buy a new pump motor, but depends what it needs
Is the hoist still available? I would like to get a few more details.
I recently put a 3 phase inverter in my shed for my tyre machine. It wasn't that difficult but the price range for them is huge! I've been told you get what you pay for haha.
- Apexi SAFC (Black) - $250 used
- Greddy Profec B Spec 2 boost controller- $300 used
- GCG GT30 0.82 rear housing (internal wastegate) - $400-$450 NEW
- wastegate actuator 12PSI w/bracket - $100 NEW
- 5 bolt dump pipe - mild steel - $150 NEW
- Oil cooler/relocator kit (fits RB) - $180 used
- R32 GTR wing - Dark metallic blue - $150 used
- Kinugawa TO4E oil drain - $50 NEW
- HKS SSQV (comes with circlip/2bolt mount to fit RB25DET standad BOV position $100 used
- Stock RB25DET ECU - $120 used
- Stock RB25DET Air Flow Meter - $120 used
- 2x Federal 595SS 245/45ZR18 (lots of tread) - $100 used
- Tein HA Coilovers to suit R32 GTST rear pair(need shocks rebuilt) - $100
- Trust Airinx air filter (should suit stock skyline AFM)- $100
All prices quite negotiable. please give me an offer.
PM, text or call 0431900505.
may forget to check this for a while so please PM, text or call
will post pics eventually, can send pics if requested
Would prefer local sale
located in Woden, ACT
Cheers
Simon
post-27427-0-78494500-1365815252_thumb.j post-27427-0-99454600-1365815254_thumb.j post-27427-0-07171800-1365815264_thumb.j post-27427-0-04689000-1365815266_thumb.j post-27427-0-52514000-1365815273_thumb.j post-27427-0-44306300-1365815275_thumb.jpost-27427-0-50180600-1365815277_thumb.j post-27427-0-61105500-1365815279_thumb.j post-27427-0-52966400-1365815281_thumb.j post-27427-0-48292800-1365815283_thumb.j post-27427-0-70125000-1365815385_thumb.j post-27427-0-39474500-1365815387_thumb.j post-27427-0-55363300-1365815388_thumb.j post-27427-0-54264500-1365815390_thumb.j post-27427-0-47027000-1365815392_thumb.j post-27427-0-22023400-1365815394_thumb.j
R34 gtt parts - NOW WITH PRICING
Bonnet - $325
Front Guards - $350 for the pair
Standard Rear Wing - $50
All parts are factory black, fenders in very good condition, bonnet has some paint scratches on the front left side, standard wing's paintwork has seen better days and is fairly faded on the top of the wing blade (will need a respray).
**The following are also up for grabs:
GENUINE Impul gtt front bar - $650
Replica 34 gtr spoiler with carbon wing blade - $300
Impul front bar is a little rough cosmetically as it had a confrontation with a kangaroo, but won. The paint has cracked and there is very slight frays on the fibreglass around the grill, but otherwise structurally perfect. Will need a respray, but well worth the price considering a new one is $1200.
Replica spoiler has never been fitted as I'm waiting on carbon wing stands from a group buy on here. The carbon blade is very good quality but the standard wing stands didn't align properly with my boot. It's a dead easy fix, but I haven't been bothered to address it.
If the carbon stands fit properly I may keep it (unless the right price is agreed upon)
PM for more info and pics.
Edited by TM7GTR
R34 gtt seats. Drivers side has a slight split on rhs bolster from getting in and out. Nothing a needle and some navy blue thread can't fix. No seatbelt stalks. Need them gone. Looking for $60 negotiable.
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
