If there was 4 of them and an appropriate offset for R31, I would buy.
R31 is +30 isn't it Eiji?
Depends on the rims. +30 is pretty safe but there are they few cheap rims made around that offset. I can only think of Speedy, unless you go something like Rota's but they are a bit newer and difficult to find really cheap.
Patty that suspension is very tempting.
How's it feel?
well quite frankly if i didnt want height adjustability i would have put them back in and sold my bc br. dampening is awesome rides so well and still handles great. makes bc br coilovers look like the cheap coilovers they are.
For sale : After market springs to suit R31 skyline wagon. I don't know if it's lowered or heavier than standard, just the the springs appear thicker and shorter than stock. $60
Also have:
- after market front sway bar $60
- Power steering rack $50
- power steering pump $30
- power steering lines $80
- power steering reservoir $20
OK, In the 3 years since I got my 33, I have Gathered WAY TOO MUCH STUFF!
This is not all of it but it's a start, Prices are ono...
Buy my Stuff and Things!
R33 S1 Turbo, minimal shaft play but condition unknown as unused by me. $150.
R33 S2 Turbo, Minimal shaft play but conditon unknown as unused by me. $180.
R33 side indicators. $15 / pair... (more than 1 pair available)
Stock Rubber intake Pipe for GTS-t $15 (more than 1 available)
R33 Coupe Rear Garnish (Clear) $50.00
Various NISSAN Relays $10 each.
GTR BOV $80 (More than 1 Available)
Some piping for GTR Bov also.
GTS-t Bov $40
R33 Crossover J pipe $20 (more than 1 available)
Stock R33 GTS-t Dump $20
New Never Used Stainless Split Dump Pipe $80
Stock R33 GTS-t Frontpipe and Gutted Cat $20
3" GTS-t Frontpipe larger section welded in the middle. Ugly but Effective. $40
Stock Series 2 R33 Coilpacks $80 / set of 6 (more than 1 set available)
Stock R33 Side Mount Cooler $50.
R33 4door Tail lights and Garnish - Both Series 1 and Series 2.
R33 Coupe Series 2 Wing (White) $100
R33 4door Wing (Silver) $100
R33 GTS-t Airbox and Snorkle $100
More will be added in time.
If it's Not Listed, I may have one... Just ask. :thumbsup:
PM is best. Pics can be provided.
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
