Now in General FS section
I've been thinking about this for a little while and I have decided. Moving on
My Silver R34 GTT - affectionately known as 'Tokyo Taxi - is up for sale. This post is to let any locals know first who may be interested.
2001 model with genuine 140k kms on the odometer
Recently Autotech put in a Nistune, Injectors, Walbro FP and tuned to 245rwkw's @ 16psi
Just prior to that the OP6 Highflowed with GCG Garret 2871
It has aftermarket FMIC, Exhaust, Dump. pod and Metal intake pipe, running splitfire coilpacks
Treads are RSR's and rims 18" Gold volk GTC's
Top Quality Clarion head unit 7", speakers and 10" woofer with enclosure in the booty
100% Aussie wool Sheepskin Seat covers
Condition
Runs great and looks great - NO issues
Registered for a few more months
Interior and exterior I'd rate as good. Some stone chips on bonnet and a minor swirl mark
Wear mark in driver side bolster (Hence awesome seat covers)
Steering wheel needs recovering or replacement
Maintenance and serviced often (you know me, OCD)
It's Auto so some young boy folks may be put off - don't be. It stays on boost under load :)
Easy to drive
After around $13k semi-negotiable
"my milk shake brings all the boys to the yard"
Hey Kat *mwah* . Not seen you round work for a while ??? Yeah I know trips O.S for work (Bitch!)
I'll be driving GTR a bit more (true) real shame to see it in the shed every evening. G o D I lurve her heaps (in ways that can should not be imagined).
also looking around @ VW Golf R's for a daily.
Can do you a better price :D for :wub: .... :P ..... :spank: (norty)
(oh and husbands are like temporary) good cars are 4eva !
Edited by Sinista32
Oh and 6 burner BBQ with Wokky and gassious bottle sold pending payment and pick-up
Sorry Anthony - too slow buddy :(
Ps. You may see Sin on Car sales soon. In deep thoughts ATM
Edited by Sinista32
Buy it :)
Edit:
Check out car sales for R32 GTR's. Sort byy high to low price..You tell me who's is better ? ADM elitists.
- So got different tail lights, centre mount arial and a Nissan badge on their bonnet (Stockers too FFS).
The price will be reasonable, and less than those top 4 Pieces Of Shit (POS), but I expect it not to move even at a reasonable price.
Edited by Sinista32
Have a Gcg high flow that I'm looking at selling as I have upgraded to a bigger turbo. It's was on my car for about 4months and I made 242kw on 20psi. Turbo is in very good condition can come have a look for yourself.
Prefer local buyer but will post at buyers expense.
Pm me or msg me on 0406376307 for quicker response.
Looking for $800 firm as I don't need to sell, can always keep for one of my other 33's
I'm located in Canberra.
Hey Guys,
Got a pair of Garrett GT2860-5 turbos, bolt on for RB26
had these in my shed for a couple of years now, with plans to adapt them to a 1JZ.
One definitely requires a rebuild the other more than likely does too.
Complete with actuators etc.
Will try and get some pics up in the coming days.
But they look like 2860-5s with grime on them.
No damage to any of the housings from what I recall.
Any questions please post up or PM me
Asking $250 posted to the East Coast or $220 pick up in Canberra
Hey Guys,
Hey Zeb im interested.
What exactly on them needs rebuilding? just the cartridges?
Where would pick up be?
Thanks
Nick 0408 513 746
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
