Now in General FS section
I've been thinking about this for a little while and I have decided. Moving on
My Silver R34 GTT - affectionately known as 'Tokyo Taxi - is up for sale. This post is to let any locals know first who may be interested.
2001 model with genuine 140k kms on the odometer
Recently Autotech put in a Nistune, Injectors, Walbro FP and tuned to 245rwkw's @ 16psi
Just prior to that the OP6 Highflowed with GCG Garret 2871
It has aftermarket FMIC, Exhaust, Dump. pod and Metal intake pipe, running splitfire coilpacks
Treads are RSR's and rims 18" Gold volk GTC's
Top Quality Clarion head unit 7", speakers and 10" woofer with enclosure in the booty
100% Aussie wool Sheepskin Seat covers
Condition
Runs great and looks great - NO issues
Registered for a few more months
Interior and exterior I'd rate as good. Some stone chips on bonnet and a minor swirl mark
Wear mark in driver side bolster (Hence awesome seat covers)
Steering wheel needs recovering or replacement
Maintenance and serviced often (you know me, OCD)
It's Auto so some young boy folks may be put off - don't be. It stays on boost under load :)
Easy to drive
After around $13k semi-negotiable
"my milk shake brings all the boys to the yard"
Hey Kat *mwah* . Not seen you round work for a while ??? Yeah I know trips O.S for work (Bitch!)
I'll be driving GTR a bit more (true) real shame to see it in the shed every evening. G o D I lurve her heaps (in ways that can should not be imagined).
also looking around @ VW Golf R's for a daily.
Can do you a better price :D for :wub: .... :P ..... :spank: (norty)
(oh and husbands are like temporary) good cars are 4eva !
Edited by Sinista32
Oh and 6 burner BBQ with Wokky and gassious bottle sold pending payment and pick-up
Sorry Anthony - too slow buddy :(
Ps. You may see Sin on Car sales soon. In deep thoughts ATM
Edited by Sinista32
Buy it :)
Edit:
Check out car sales for R32 GTR's. Sort byy high to low price..You tell me who's is better ? ADM elitists.
- So got different tail lights, centre mount arial and a Nissan badge on their bonnet (Stockers too FFS).
The price will be reasonable, and less than those top 4 Pieces Of Shit (POS), but I expect it not to move even at a reasonable price.
Edited by Sinista32
Have a Gcg high flow that I'm looking at selling as I have upgraded to a bigger turbo. It's was on my car for about 4months and I made 242kw on 20psi. Turbo is in very good condition can come have a look for yourself.
Prefer local buyer but will post at buyers expense.
Pm me or msg me on 0406376307 for quicker response.
Looking for $800 firm as I don't need to sell, can always keep for one of my other 33's
I'm located in Canberra.
Hey Guys,
Got a pair of Garrett GT2860-5 turbos, bolt on for RB26
had these in my shed for a couple of years now, with plans to adapt them to a 1JZ.
One definitely requires a rebuild the other more than likely does too.
Complete with actuators etc.
Will try and get some pics up in the coming days.
But they look like 2860-5s with grime on them.
No damage to any of the housings from what I recall.
Any questions please post up or PM me
Asking $250 posted to the East Coast or $220 pick up in Canberra
Hey Guys,
Hey Zeb im interested.
What exactly on them needs rebuilding? just the cartridges?
Where would pick up be?
Thanks
Nick 0408 513 746
