Hey all I've had these wheels sitting around for ages and have decided to try and get rid of them
Rota grids. Fronts 18x8.5 235/40 with 3-4mm left of tread. Rears 18x9.5 265/35, already at the tread wear indicator. Offsets are around 30ish.
Two different colours - don't ask me why... Previous owner..
$500neg
SOLD
Edited by dontyellpl0x
  • Like 1
thinking about selling up my r33 build, take a look guys
http://www.sau.com.au/forums/topic/454741-eoi-r33-rb25-build-sell-off/#entry7496457
I'm interested in the hicas lockout and the coil overs
http://justjap.com/driveline/genuine-nissan-gearbox-nissan-skyline-ecr33.html
And you want a thousand more for your secondhand box.
Good luck you fkn scab.
Im sick of people selling sht for WAY more than its worth, fk you all.
Edited by D.I.Y. Mik
Anyone have a strut brace suitable for an r33 gtst they want to sell?
Front? Are you on Facebook?
This isn't in Canberra but could be cheap
https://m.facebook.com/groups/2786712445?view=permalink&id=10153238880542446
Edit: post seems to be gone sorry :(
No Worries Dontyelldude. Thanks for the lookout!
Yes front. Trying to make my car less like a snowplough.
Try this. ---> http://www.gumtree.com.au/s-ad/dickson/auto-body-parts/r33-engine-strut-brace/1072388187
