Hey all, I sold the stagea and have some parts id like to sell so i can get parts for my wrx.
- I have Sard 720cc injectors which I got on Sinista
- Brand new Nismo FPR
- Brand New Caster Arms to suit R33 GTR unsure of brand
- OS Giken twin plate clutch requires rebuild
Let me know if you'd be interested in them 0408513746
Edited by Verms
Set of 4 Starcorp Pro V 5x114.3 18x8 +38. made in Taiwan.
I was going to fix these up and put them on the B17 Pulsar, they have minimal rash but some scratches on the faces and have just a light coat of silver over them for a temp fix.
(overspray included)
post-78856-0-79972700-1429423411_thumb.jpg post-78856-0-02928000-1429423452_thumb.jpg post-78856-0-61193300-1429424082_thumb.jpg
225/40ZR18 all round. 2 x Federal 595 and 2 x BCT S800.
Federals have heaps of tread, BCT are just above the marks.
$200 ono.
Set of 4 "ASSO" rims only. 5x114.3 16x8 +36. made in Japan.
These were the rims on my R33 when I got it.
post-78856-0-88871100-1429423476_thumb.jpg post-78856-0-76502600-1429424116_thumb.jpg
Powder Coated Grey with some scratches / marks.
$250 ono.
Set of 4 of these... Toyota Tarago? rims. 4x114.3 14x51/2 +27 made in ya Mum.
post-78856-0-14911200-1429423374_thumb.jpg post-78856-0-58161100-1429424821_thumb.jpg
Tyres are no good.
$50 ono.
Garrett GT30, 0.82 rear housing. Internal wastegate.
$230 - Pick-up from Canberra preferred, can post at buyers expense.
Item has never been used, it was part of a GT3076R kit purchased from GCG a few years ago.
Please Pm here, or call/sms 0431900505
Was chasing after this almost a year couldn't find one so i bought one for $800 brand new :(
GCG told me that garrett discontinued making this type of rear housing
Ah damn it, it was you id spoken to!
I thought id sold it but I found it in the house move. By then I couldnt remember who was looking for one.
full set of 6 standard rb25det injectors with rail and reg.
one injector is suspect...I dare say just gummed up due to sitting for months with e85 in the tank and will only require cleaning.
but selling cheap due to the unknown nature of the problem.
$40.00
    • Did you pay with a credit card? I'd be putting a charge back through then finding a new sparky to sort it out.
    • If you mean the alarm immobiliser; theyre internal to the alarm itself which makes that difficult; I couldnt even see where he put it; its not in the same place as last time; but with all black wiring it might be very challenging to trace  I had someone turn the key for me as I know it only primes for a couple of seconds As my post above; I am getting no voltage to the pump at all; but I am testing continuity of the power line (SB) from the pump plug to the relay fine. As well as the negative from the pump plug to a 12V constant.    Yeah; he blammed the no start on a bad battery; said I needed to get a new battery and it'll start. Turns out the battery drained because the tail lights had been on for half the day during the install (the rubber cushion on the brake switch gave out while he was testing it as I have a picture of the car from that morning with the tail lights off..i've replaced that). The battery was turning over the engine just fine for a long time; but got low since lights were draining it so it was too low to test a start after he finished. I bought a new one on his advice...$250 wasted. My original battery charged up just fine and is healthy.    It was running perfectly fine when I messed up the old alarm (programmed out the remotes). He couldnt start it after removing the old alarm; my assumption is that when he unhooked it; he didnt bridge the circuit back when trying to start it. Its always been perfectly fine. The ECU swap and pump were 2 years ago. It's never missed a beat in that time.
    • This is a big issue for me without the diff. I just have zero drive from the passenger side when drivers side has no traction. Bec's parents place has a crazy steep driveway with odd camber and I have never been able to get up. My bro-in-law's 130i with an (unknown brand) LSD gets up fine as does their dad's Hiace. My car stays at the bottom. We have other odd camber roads around here as we're elevated a bit and if it's raining I can get totally stuck around some hairpins.
    • Yeah, I am super excited for this.
    • Was the car running before he touched the car?
