R32 GTR cradle no hubs/brakes/diff or driveshafts. Has a HICAS lock bar and knuckles. $100
R32 GTR rear struts with king springs. One has damaged thread on top of the shock. $80
Still got the R32 GTR HKS Drag rear coilovers $300
FJ 720 do you still have the HICAS lock bar on the R32 rear cradle?
K&N panel filter for RB26DETT part no. 33-2031-2. Used for approx. 20k. Includes new bottle of power kleen and almost new can of spray oil (only used once for initial light coat). $80 ono.
price drop $60
Walbro 400l fuel pump did less than 500km, come with wiring and new strainer $50
Rb30 fuel rail new with an6 and an8 fitting also to suit 14mm or 11mm injectors with adaptors all included $150
Rb25 candy blue rocker cover $250
Rb25 clear cam cover used still in good condition just needs a good clean $50
Rb25 head with stock cams stock valve spring etc but no valve seals or rocker covers $100
Rb30 head $100
Rb25 block with blown piston ring $100
Rb30 block $150
Rb25 S1 afm $50
Rb25 S1 Throttle body and throttle position sensor $60
Rb25 stock fuel rail with stock injectors $50
Rb25 injector loom $40
Wouldn't happen to have a decent condition rb30e harmonic balancer for r31 hanging around?
Rb30 head $100
Rb30 block $150
Rb25 S1 afm $50
R31 RB30 harmonic balancer are normally single piece while VL RB30 harmonic balancer are two piece as Shiv pictured. However I have seen two piece on a R31 before.
The Rb30 engine i have came out of a R31
Can you post up a pick of the side of the thing, if I can see if it has ribbed belts or v-belts it will give me a better idea (my rb30 has ribbed)
Looks similar to mine except mine is a single piece (and, um, has a massive chunk missing out of it):
rb30e%20harmonic%20balancer.jpg[/url]
rb30e%20harmonic%20balancer2.jpg[/url]
Anyone know if these would be interchangeable?
Edited by dorifticon
bump make an offer guys
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
