R32 GTR cradle no hubs/brakes/diff or driveshafts. Has a HICAS lock bar and knuckles. $100
R32 GTR rear struts with king springs. One has damaged thread on top of the shock. $80
Still got the R32 GTR HKS Drag rear coilovers $300
FJ 720 do you still have the HICAS lock bar on the R32 rear cradle?
K&N panel filter for RB26DETT part no. 33-2031-2. Used for approx. 20k. Includes new bottle of power kleen and almost new can of spray oil (only used once for initial light coat). $80 ono.
price drop $60
Walbro 400l fuel pump did less than 500km, come with wiring and new strainer $50
Rb30 fuel rail new with an6 and an8 fitting also to suit 14mm or 11mm injectors with adaptors all included $150
Rb25 candy blue rocker cover $250
Rb25 clear cam cover used still in good condition just needs a good clean $50
Rb25 head with stock cams stock valve spring etc but no valve seals or rocker covers $100
Rb30 head $100
Rb25 block with blown piston ring $100
Rb30 block $150
Rb25 S1 afm $50
Rb25 S1 Throttle body and throttle position sensor $60
Rb25 stock fuel rail with stock injectors $50
Rb25 injector loom $40
Wouldn't happen to have a decent condition rb30e harmonic balancer for r31 hanging around?
Rb30 head $100
Rb30 block $150
Rb25 S1 afm $50
R31 RB30 harmonic balancer are normally single piece while VL RB30 harmonic balancer are two piece as Shiv pictured. However I have seen two piece on a R31 before.
The Rb30 engine i have came out of a R31
Can you post up a pick of the side of the thing, if I can see if it has ribbed belts or v-belts it will give me a better idea (my rb30 has ribbed)
Looks similar to mine except mine is a single piece (and, um, has a massive chunk missing out of it):
rb30e%20harmonic%20balancer.jpg[/url]
rb30e%20harmonic%20balancer2.jpg[/url]
Anyone know if these would be interchangeable?
Edited by dorifticon
bump make an offer guys
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
