  • 3 weeks later...
For Sale:  a set of 17x9.5 +35 & 17x8.5 +35 Work Meister Monoblocks in black.
Have looked for similar wheels to set the price but have been unable to locate an equivalent ad.
Last I saw an ad for them in this size was around $1800.
They're super light and I would love to keep them but need wheels for new car.
Edited by MANG
forgot info
Hey guys,
Have an r33 Nismo catback for sale.
Good 3" quiet exhaust. Would pass rego inspection. Centre muffler is a bit crushed, I bought it like that.
$400ono.
Cheers,
Chris
Hi guys.
Chasing a non neo rb25 head for a rb25/30 build. Prefer something rebuilt.
Just bought a gtt with an rb25/30 in it and just found out there is a crack in the head. Can't be welded. Thought it was just a gasket but unfortunately not.
Send me a text or call if you have something of use.
Thanks in advance.
Dean
0434497483
  • 1 month later...
For sale: for you ACT GTR/RB26 nuts.
1 x Trust intercooler. 600x300x65mm. The usual finning that has been folded due to road use, I had this fitted to my car for 14 years with no issues. Whilst I never removed the original Intercooler to replace it with this one, I'm lead to believe this was a direct for to the standard mounting points.
AP Racing triple plate clutch + flywheel. I never had this in the car, but I'm told by the previous owner it was a) built for big HP uses(obviously...) and b) it was HEAVY if you were considering fitting it to your daily...
I don't have many more details on either, but rest assured they haven't been used much as the car hasn't been on the road for 11 years and the clutch was never fitted in the first place.
$250 ea not negotiable or $400 for both not negotiable.
I thought I'd offer it up to the ACT crew before I list it nationally on SAU.
Cheers, Jayce. d5b968f53119a60857a8318dcd5b21a5.jpg02dfc5cbc22b1b670cf3ee94f2f734a1.jpg
Might be interested in that clutch, as i suspect my nismo one wont hold much longer. Any hotspots or anything?
Sorry from the late reply! Damned notifications not coming through...
It's never been apart since I've had it; it was too heavy for the previous owner so he had an easier one fitted and gave me the AP when I brought the car in 2004. I was keeping it for a higher HP application, but my needs have changed(plus not having the car on the road...for 11 years and counting), hence why it's up for grabs. I can't truthfully say if it has got spots, but it would've needed a heap of abuse from a 1000hp car to do so, and that isn't my car, so I'm confident in its state! Feel free to have a look if you want!
Ill pm you.
  • 1 month later...
Hey all,
Selling Whiteline sway bars to suit r33 gtst. Brand new, never ended up installing them.
BNF24Z 24mm 4 point adjustable front - $250
BNR11XZ 22mm 2 point adjustable rear - $200
KLC108 Front sway bar links - $120
Happy to let it all go for $500.
Can supply photos if requested.
Cheers,
Chris
On ‎3‎/‎01‎/‎2017 at 2:45 PM, Sinista32 said:
Folks - clearing space
Let me know if your interested in these - FOC for ACT folk (must have a 32 though)
FOC = Free of Charge
No takers going in the rubbish. Would be a waste :(
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
