Thinking about selling my R32 as a rolling shell (no engine, gearbox or diff). It will however come with another RB20DET, gearbox and diff with the sale. Not very pretty because I've been using it for drifting, but R32's look so cool.
It does have on it:
- Adjustable castor rods
- HSD coilovers but one dampener needs a rebuild (bound feels like it's blown out).
- Has Potenza front struts because of the coilover problem
- DVD player and motorised touch scren (1 DINN)
- Project Mu front brake pads
- Bosch 040 intank pump with relay from battery
- 2.5 months rego
- Hicas lock bar
- GTR rear cradle (suspension knuckles)
It will also come with separate:
- Original RB20DET (I was running a RB25)
- RB20 gearbox
- VLSD
- Flywheel, HD clutch/pressure plate.
After $2500, I think I can wreck it down for the same price. If you're after parts let me know and I'll consider wrecking it down sooner if I have enough interest. I might even put a RB30 into it in the mean time.
EDIT: No pics of it at the moment, any that I do have I don't want to post :P.
R32 forsale price without particular bits:
Rolling shell - $1700
- 2.5 months rego
- Hicas lock bar
- 3 Inch Cat Back exhaust
Rolling shell with gearbox & Diff - $2200
- 2.5 months rego
- Hicas lock bar
- RB20 Gearbox
- VLSD
- Flywheel, HD Clutch/pressureplate
Rolling shell with Engine, gearbox & Diff - $2700
- 2.5 months rego
- Hicas lock bar
- RB20 Gearbox
- VLSD
- RB20DET engine, loom, computer, afm, sidemount, etc
- 3 inch split pipe/screamer
* Car will come with different wheels (Evo rims or 15/16's).
* Greddy Intercooler is not included
Hey Peeps,
Selling my tow car and trailer because I need the cash for a house.
Details are
2006 Ford Transit MWB
6sp Manual
Turbo Diesel
207xxxkms
Cargo Barrier
Rear Spotlights
4.5t tow bar
Can tow a car on a trailer plus half a workshop in the back combined towing capability is 5 tonne
Also selling with the van is my tilt car trailer.
2 axle with front storage compartment
tilts with ramps that is hidden underneath the trailer
(Trailer will not be sold unless van is sold)
$16,000 ono
I Have a bunch of stuff that is taking up room in the shed that id like to get rid of, but i only really want to sell locally because of the size of most items:
driver and passenger r33 s2 front seats in great condition
r33 s2 rear setas, also in great condition
kr4 silver r33 gtr rear spoiler
pair of 17x9 +38 wheels
can get pics if people are interested in any of it
tumblr_m939xa1a3Z1qamz4to1_400.giftumblr_m939xa1a3Z1qamz4to1_400.giftumblr_m939xa1a3Z1qamz4to1_400.giftumblr_m939xa1a3Z1qamz4to1_400.gif
Airbox sold..
Everything still available for $50 pick up.. will throw in a free Pure Blonde to anyone that buys something... (sorry Kurtis; I forgot to offer)
All parts taken from 1999 S2 C34
Stock Turbo Dump Pipe - C34 Stagea (will it fit 33/34?)
SMIC
Knock Sensor - Suit RB25DET
Complete 3 inch turbo back exhaust for a 33 gtst.
Bellmouth advance dump modified to fit a hotdog muffler in before the cat.
Dump pipe has been painted in high temp exhaust paint (supposedly has ceramic in it) and wrapped.
Cat is complete, not bashed out or "high flowed"
Single straight through box muffler before the rear subframe.
3 inch twin pipes or cannon out the back, both will be provided.
$300 neg.
3.5 inch cat back to suit 33
single hotdog muffler before rear subframe.
Cannon at the rear.
$150 firm.
Brand new fibre glass gtr style front bar to suit 33 gts/gtst
Sold the car before it was fitted.
No holes have been drilled yet.
$150 firm.
Pm, or Text me on Zero 415 055 80 Nine
Cheers,
Jono.
pics are available here:
http://www.skylinesaustralia.com/forums/topic/415041-r33-exhausts-and-gtr-copy-front-bar-to-suit-gtst/
more available upon request
Edited by reaper1721
I have some std rb26 cams and some r32 gtr/gtst-4 afttermarket shocks and springs. Shocks are kyb damper adjustable, springs are unknown. Ride was quite stiff for me, not sure if it was due to incorrect setup or what, buyer might want to inspect before buying. $50 for the shocks and $100 for the cams. Pm me if keen, located in belconnen.
I have a set of 'Juran' struts (4) that were fitted to my Stagea.
They came from Japanland with them on and couldn't find too much info on them.. other than they're pink.
6 level dampening..
$20. pick up from Banks.
6 level dampening..
Is your stag the silver one i see poking around banks?
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
