you have broken into 1.5s for your 60footer which is simply incredible!
my previous r32gtr which had 320awkw (street car) & knowing that the r32 is only 1450kg which is light in comparison to the r35 (what do they weigh?), i was running MT drag radials & launching off the limiter took me to my PB @ 1.5s
...you have just about matched that with street tyres, btw u have a beautiful package (that doesn't sound right hehe)
  • Replies 167
looks like toyo 888's + volk g2's
i went out to do a 60-130mph pull and was loosing traction in 3rd and 4th with my 21" yoki advans - im going to grab a set of michelin super sports asap
grip with my yoki's has just fallen off so quickly, 2nd gear is pretty much useless in this dry cold weather
Edited by domino_z
what an awesome problem to have :)
Martin what wheel and tyre combination have you fitted in these pics?
Domino was right
Toyo R888 tyres on Volk G2 black rims, 10.5 front, 11 rear
WR600 has a black/black theme going, even has the black carbon Velo race seat and black harnesses :)
Now we have the tuning where we want it the WR600 will be back at the strip next meeting on some fresh boots to run down a 9 second pass. The Syvecs management system truly allows some amazing advances in tuning these cars, like the ability to have traction control that keeps the car totally under control in the wet, so very very different to factory :)
Yes it would be I believe Domino.
Running a 9 is no burning desire for us though, been there and done that many times with the older GTRs before and know the procedure fairly well. It will be given a go, but not as a priority if you like.
We certainly wont get involved in the US game of winding the things up till they go 9s or splatter conrods all over the track just to post a timeslip on a forum. In our opinion GTR is about much more than that. 400m times are interesting, but about 1/10th of the GTR story :)
You only have to look over @ NAGTROC to see the tranny failures and other issues, and of course 99% of them on big power mods and owners wondering why it broke LOL... Good to finally see someone with their head screwed on Re: Power modding :)
US Tuners/vendors are victims of the typical American consumer - I'm sure if they wanted to they could focus on circuit setups vs drag, but the typical American thinks bigger is better and will happily pay for it, so they're stuck competing with each other for dyno number thread glory and drag times
Edited by domino_z
And totally missing the point of GTR in the first place.....
There are much better cars for dyno racing or drag racing, just not many better actual cars though :)
We keep a lot of the stock suspension rehab. In fact this run was on - totally - stock suspension. However in the next few weeks we are integrating some roll stiffness and camber into the car with our suspension development partner Whiteline :)
Some installation shots of the WR600 MY12 Willall Racing/Whiteline suspension tweaks (note on earlier models we change the spring/damper combination as well)
Camber offset bushes installed in top arms
With the camber bushes and castor bushes in place the MY12 can deliver -3 degrees negative camber in the front end, which is preferable for fast track work, and still be dialled out for street dutires
Front roll bar stifness has been changed to stop the car kneeling over on the outside loaded tyre, which is a major contributor to the beating the GTR gives its front tyres at the track, and a major contributor to understeer
Upgraded rear bar balances the effect of the front sway bar change to keep the chassis neutral
    • Resizing injectors in Nistune can be done a couple of ways, and there are a couple of ways that you can make a mess of it. The tuner needs to be really aware of the effects of whichever approach he uses (either K, or TIM). They are both easy enough to "get the injector size right" to run the engine. But little details like old start enrichment and hot start are affected differently, depending on which boxes you check.
    • Pretty safe to say almost everyone that has tuned their own car has experienced this issue. The difference being that we have our laptop in the car and when it happens, it's literally 10 seconds of tuning to sort it.  Would you be happy to plug in your laptop and sort this yourself? It is a very simple process and there is no risk of harming your engine (if you are worried about that).
    • Yeah thats the next step now, either they wil or i will take out for a drive to work and go straight their after work and see is we get the same issues 🤞  thought i try my luck here too, never know someone else might have had the same issue but thanks for the reply
    • Basically your tuner needs to drive it for the 30 min (or whatever) to create the same conditions then check the ECU settings and sensors at that time. They may not be excited to because that takes them 30 min rather than just opening the bonnet and seeing the problem straight away.... Hot start is generally not as tricky as cold start, but there would be a table for fuel enrichment vs coolant temp as a starting point
    • Yeah, they all cant say anything for sure as everything is working fine . Said unable to find an issue untill it stops again. Could mist likely be CAS wiring or IAS valve issue but again not 100%
