hey guys, im keen on getting a bit of a bov pressure release sound, similar to what you get when you use a pod, but i would rather not put a pod in, so is there any DIY mods you can do to the stock bov to make the pressure release noise louder? theres people who do the old block off the bov mod, but i hate the flutter noise, not to mention the possible implications of disabling the bov.
cheers
https://www.sau.com.au/forums/topic/399978-stock-r33-bov-noise-mods/
Can get some gasket paper and cut it to the shape of the flange, then make the hole in the middle smaller than the actual hole. I did it in the hopes that it would shut mine up a bit, but it did the opposite and made it louder.
wont gasket paper just blow into the recirc piping?
Edited by ClutchBurndout-:(
Its not quite what you try to do, but loosely based on it so I'll paste it anyway.
I've actually got a copy and paste space where this is. Read on.
I love these threads.
You love the noise - and put the BOV on the car to be a wanker. Its scientifically proven that if you're a wanker, the first thing you do when you buy a Skyline is install a vent to atmosphere blow off valve, to advertise the fact that you are indeed, a wanker.
Do you even know how the Nissan air intake system works? There is an AFM that measures the air entering the engine. The Stock BOV recirculates FOR A REASON. When your duck whistle, twisty whooshy twirly, dick pulling, sparkly, spinny, shiny, noisy, fuleh sic, wank off valve opens, it dumps air that the engine has measured and allocated fuel for. When only half the air gets into the cylinder because the air it measured is at the street corner where you sped up erratically and backed off because you saw some women on the corner, thinking that when they heard your BOV they'd get naked and run and dive into your car, the engine is now overfueled and under oxygenated, and stalls, backfires, and carries on. You know why? Because you've created a MASSIVE AIRLEAK on a system that will not run with airleaks.
Do you like that fact that you will foul your plugs constantly?
Do you also like attracting the cops attention?
Do you like the risk of being defected and having to pay money for a BOV that didn't need to be there?
Do you like the fact that you are just making skylines more hated? (And don't worry, its almost a guarantee that you'll drive through the main street of town making it release "because you like the wank off sound")
Do you like it how women love the sound, get naked and dive into your car as you drive past?
Do you think SAU will be happy about another "My car is running rough, I only installed a duck whistle, twisty whooshy twirly, dick pulling, sparkly fuleh sic wank off valve" thread
They should create a database script that bans people that install BOVs "just for the sound" or complain when their car runs rough...
I'm was running 300rwkw and had the stock BOV.
Good luck with it though.
[quote name=ClutchBurndout-:(' timestamp='1336902464' post='6354778]
ok
anyway, so what im gonna do is make the hole maybe 10mm, and i think ill be on the money as far as sound goes.
Why dont you just buy a Pod Filter? and if your worried about hot air or defects, buy a cold air box for it
Rather then spending 200 hours trying to Mod the standard BOV
  • 6 months later...
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
