Have just put the engine back into the car, it starts then instantly dies, when I unplug the afm, it starts and runs, soon as i plug the afm back in, it idles high for about 3 secs then dies.
Its a r33 with s2 engine. Have just installed the following:
-Gt35 turbo
-front facing plenum
-z32 afm
-555cc nismo injectors
-nistune (stock tune with z32 and 555cc injector changes)
-fmic
-040 pump
-timing belt, water pump, spark plugs (7 heat, 0.8mm gap)
Not sure what the problem could be, any ideas? What can I check? Thinking it could be a vac leak, may something to do with aac valve, dont know.
https://www.sau.com.au/forums/topic/400430-r33-not-running/
If you plug the AFM in, and the car dies... And you take it out and it idles...
Tried another AFM? Is the AFM throwing a fault code/sensor?
Might be a VAC leak but it'd have to be a rather large one. Sure you've sealed the plenum correctly?
https://www.sau.com.au/forums/topic/400430-r33-not-running/#findComment-6360654
I know when Dvs Jez was tuning my car with the nistune z32 ecu base map for r33's and just updated the afm and injector settings for 555's and z32 afm, it wouldn't really run. He had to fiddle with a few settings to get it to idle properly.
https://www.sau.com.au/forums/topic/400430-r33-not-running/#findComment-6360872
Correct. Its not as simple as selecting the afm and injectors and drive away.
K const needs to be adjusted to get it running
https://www.sau.com.au/forums/topic/400430-r33-not-running/#findComment-6360878
A Nissan ECU measures the AFM voltage, and uses the VQ curve to convert that to an amount of air flowing. The ECU then calculates the injection time by multiplying the revs by the air flow value by the K value (basically). If you put bigger injectors in, you need to reduce the K value, as you don't want to the bigger injectors to pulse as long as smaller ones. If you change the AFM (physically), then you change the VQ map in Nistune to reflect the different voltage-flow relationship and you have to adjust the K again.
The built in functions for resizing injectors and AFM in Nistune do this for you by simple ratio calculation between known (assumed) sizing of injectors and known (assumed) performance curves of the air flow meters. But such simple maths does not capture the fuzzy edges of the differences between things you change, and worse, with injectors the latency can be quite different, which is not automatically updated when you use the resize functions. End result, it is more normal to have to manually tweak the K value to get it to run properly, fairly common to need to adjust K to get it to run at all, and almost unknown to be able to swap stuff around without needing to touch the K value at all.
https://www.sau.com.au/forums/topic/400430-r33-not-running/#findComment-6361463
That's the point....it is very specific to your setup. Here's my tip. In Nistune, with the basic changes for AFM and injectors done, increase the K value by 10% and see if that makes it better. If not try +20%, +30%, maybe even higher. If none of that helps, try -10% and so on. When you find a change that makes it better, then try 5% changes around that.
https://www.sau.com.au/forums/topic/400430-r33-not-running/#findComment-6361731
Hi All,
I'm a noob so I'm not sure if I'm on the right thread or not, but here goes..
Last night I did the mod where you ground out the boost solenoid on an R33GTSt.
Well I read the entire thread on that before attempting it, & then did it as specified.
When I went to test it on my way to work this morning it would not rev over 2500rpm, just kept coughing until i dropped the revs below 2500.
I freaked out (i only just got the car), & put it back to standard, but it still wont rev over 2500rpm..
Have I broken something? Can I fix this?
So far I have reset the ECU as specified (disconnect batt & pump brakes)
I hot wired the solenoid to see if it works (it does)
& I tried running the car with the solenoid grounded & ungrounded.
Still only 2500 rpm..
Please HELP!!!
https://www.sau.com.au/forums/topic/400430-r33-not-running/#findComment-6380472
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
