  • Replies 99
the stock gauges are pretty shit, what air filter have you got on it?? defs recommend a high flow panel filter. same if not more power the a pod filter and its legal :)
other then a crap reading from the stock gauge, or the car not being able to breath or fart, i got nothing :P
do you know if its got the stock boost solenoid and all the standard tube setup?
Thinking of getting a water compressor or whatever they are called and a foamer... And give it a good claybar/polish/wax :D
My plans for the car is of course - zorst - FMIC - Boost controller - Tune . And hopefully be able to leave it at that :D
hopefully........ hahaha
Cheers
Colin
It wont....
I did similar thing
bought mine 100% stock
then pod, then cat back.
was happy for a month.
then turbo back exhaust + FMIC plus boost controller
went well until clutcfh died a week after
then had a fuel cut defender - SHIT.
ended up going to Unigroup where that was removed, other stuff fixed up
new ECU in,
car was great, 195rwkw on 10psi
not long after..
HKS GT-RS turbo, plus this and that (still standard motor) and made 255rwkw
and motorsport got the better of me.
keep it stock hahahahahahaha
no really, keep it stock and buy a second one already modded, it'll cost you the same in the loing run!!
In stock form boost stays at 5psi until 4500rpm then goes to 7psi, completely normal.
High boost solenoid mod is the first thing most people do. If you get a boost controller 10-11psi is as high as you can go before the ECU goes into rich and retard mode.
Word of advice, if you are on a budget just stick to the basic boltons. When you get to the point that you need to upgrade the ECU it starts to get costly.
Also have a clear idea what you want to do with the car BEFORE you start spending money, that way the path you take will become a little bit cheaper.
Hi guys, is it true that i can run approximately 10/11 psi on a 34 gtt intercooler if i swapped mine out?
Looking at maybe getting an exhaust with dual tips and a 34 intercooler so i don't have a huge slab of metal on the front keeping it looking stock =)
I can't afford to get a another one and want to slowly build this one up to a reliable ~ 200kw =D
hopefully 200kw = turbo back + 34gtt intercooler + boost controller and maybe a tune :D
Stock cooler is fine for 200rwkw, dont really want to get an ECU and tune for 200rwkw either.
Air filter
turbo back exhaust
11psi
You will have near enough 200rwkw.
Are you saying i can run my stock 33 cooler on 11psi with no issues? I always thought to run anything higher than 7psi i'd have to upgrade.
Would it be better to run a 33 or a 34 cooler?
Having a sidemount will be AWESOME to maintain awesome stock looks! and save some $$ =D
Thanks
Colin
Found out my issue about not running 7PSI. Was just my stupidity again. Read the dash properly and its in MMGH or something, and i googled it and got a converter which is saying its approximately 7PSI.
Will be installing a boost gauge asap to get a proper reading!
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
