Hey SAUers, I'm not sure how best to describe or if others will understand, but I'll try!
At high speeds, 100kmh ie, even going along straight the car seems.. unstable. Not that it jumps whole lanes, but it feels to me at least like a spider on a hotplate or on ice.
And yesterday after driving in St Kilda for a while on REALLY bumpy roads, it was even happeningish at lower speeds. Once I almost sideswipped a car next to me (I was inside lane, thank god it didn't go over to oncoming traffic), the car just suddenly started going left and I had to turn the wheel right.
Anyway, it is at mechanics, hopefully they find a bush missing or something extremely loose, but does anyone have any ideas?
I realise it is a GTR and has tight suspension and so on, but it seems to me that it isn't just being sensitive to the road.
Cheers!
Don't know about lock bar, but I'll relay that it could be HICAS.
Definitely makes sense that it would be HICAS, as it is definitely some sort of weird steering thing that doesn't affect the steering wheel itself.
Oh another thing, it also seems to happen more not just from going over bumpy things, but by fanging it. IE 1st 2nd to 100kmh, it definitely feels wobbly.
Hicas eliminator is good because it eliminates the outer tie rod ball joints.
More expensive than a lock bar but cheaper than tie rods and ball joints
Those outer rear hicas ball joints are expensive and hard to find.
I think the bearings are ok. Both rears were replaced like 6 mo ago. Bushes should be OK, lots were replaced 6 mo ago as well when I replaced much of the rear.
I'll see what they say then perhaps think about lock/eliminator. I don't really plan on racing or whatever so I'm not sure the pros or cons of having it in for the street, but if it isn't much more then I guess I can go for it.
Meh I'd rather avoid defects to keep life simple.
What does it really do to the driving experience? My mate loves my car and he's got a massive single turbo 1JZ MKIII supra with a crazy diff (only goes to 45kmh in 1st lol) although i suppose his suspension is older and not as good.
Mk3 Supras are a little crude in the rear suspension, but not terrible.
HICAS is intended to produce slip angles at the rear as you turn in, to make the car more responsive to changes in direction. It is also supposed to make continuous small tweaks to the rear steering throughout a corner to keep the car on line. In reality, whilst it may enhance turn in (desirable), what it really does when you are fanging is make the rear do things that you were not expecting. Makes it very uncomfortable to drive fast. And that is while the system is still working properly. Once it starts to f**k up, all bets are off.
They re-aligned it.
It seems better, but still is a massive problem. Twice tonight on the way home along royal parade the car had a mind of its own and decided to 'jump' to the right. Thankfully they are only smallish ones and I react in time, but... damn.
What size / width tires are you running? Wider tires with a lower profile tend to "tramline" or follow the grooves in the road. Wide semi slicks are notorious for doing this, and the car feels like it pulls randomly when it hits a different angle on the road surface. Wide street tires tend to have the same effect.
I'm not sure I will check but they aren't low profile. 265R19 I do believe.
I'm starting to think its gotta be something in the suspension and steering rather than the wheels because sometimes when I break (sometimes heavilyish) the car will pull to the left/right and the steering wheel will actually turn a fair amount as well if I let it.. perhaps?
They re-aligned it.
Can you post how much toe in they dialled in - I had my car aligned too when I just bought it, felt shocking to drive - tramline central, then I went back to the alignment place and checked the toe in, which was left at 0 - now its 1mm or something like that, sensitive but much better.
265's wouldn't help much either - tramlining you all over the place.
I had the same issue with the hicas, after 70km or so it would just kick the ass out but always the same way, i believe the drivers side rear...would slide to the right, very scary, i had the whole system removed and the lock bar installed. I would have rather keep it, but just way too dangerous.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
