Been on the search all day looking into which pump/injectors/fpr (if any?!) would be best for my setup & budget, I've gotten some info, but still need more.
After 300awkw & e85 out of my rb25 (in r32 gts4)
Injectors- looking at ID1000's / a big injector suitable for e85?
Pump- walbro intank 400lph
Fpr- still stuck regarding sizes/turbosmart/SARD?
I know I'm after rising rate, but are there many benefits vs brands? & what's the difference between turbosmart frp800 & the fpr3000?
Are all fpr's suitable for ethanol?
Cheers
https://www.sau.com.au/forums/topic/401452-e85-fuel-system-build-up/
Check that things are E85 compatible...
My setup -
1000cc XSPURTS
HKS FUEL RAIL
BOSCH 044 intank
SARD REG - However this may change as its not E85 approved... So although it MAY be fine, its not approved like the others on the market are...
There are so many cars running that sort of power on E85 on here and a lot using diggerent combos.
If your on a budget there are plenty of options :)
Thanks for your reply,
Xspurts- I've never heard of them, any good? Good spray pattern etc? 100% E85 safe?
I almost bought 1000cc rc injectors, only to find out they have to be 'flushed every few tanks with normal fuel'... So no dice.
I didn't know 044's could be intank mounted? I still think I'll go walbro 400lph because it comes with a mounting kit for an r32 + only $170 inc shipping.
As for fuel rail I'm going to go eBay spec one that comes with my proboost ffp. Hope it's e85 safe.... Ha :/
Xspurts are sold by Injectors online, they are Bosch ev14's.
http://www.injectorsonline.com/categories.php?cid=106
I have been running these for over a year now on e85 without a problem. Contact them about an SX reg too.
Those injectors look alright, but I'm on the hunt for some 1000cc's @ $100 each or less. Found ID1000's come close @ about $109 each...
As for the fuel pump yeah I'll make sure it's e85 safe. What do I need to do with my fuel lines? E85 will eat my stock lines right? Do I need to go bigger diameter too?
So why do so many people have after market fpr's? Will it be easier for tuning with a fpr?
Where are you finding the ID1000's for $109? I'm after a set atm.
I think the guys running side feed from factory need an a/maker fpr if they are changing to top feed as you then obviously need to change to top feed fuel rail so the factory fpr won't fit. Plus you can then bump up the base pressure a tad to get that bit more from the injectors.
Edited by slippylotion
I hope you're not going to not buy the ID's because they're $56 more than your budget.
E85 won't 'dissolve' your standard fuel lines. They're fine.
If your injectors are big enough (which they will be), leave the OEM FPR.
Its only OLD fuel line that has this issue yeah? I re-run all the lines in new EFI hose so i hope it will be all good!!
And i spent more than the link above for the XSPURTS as i figured they are a crucial part to the build so why skimp on them :D
Are you talking about the rubber or steel lines?
If you're talking the steel hard lines then they are fine. Mine have not dissolved or 'turned into a pile of ash on the floor' like some people believe this stuff will do!
Nah, i meant the rubber hose!
Xspurts = ID's = Bosch ev14's.
http://www.xspurtinjectors.com/
Start life as a Bosch and then get modified slightly?
My mistake, $119, not $109. So $720 a set.
I meant are there any other 1000's people are running e85 on that are decent & under $600 for a set. Just curious.
I've seen rc1000's for $550 but their not e85 safe
I remember reading about cheap injectors here -
http://www.skylinesaustralia.com/forums/topic/297224-installing-seimens-deka-injectors-onto-a-neo-rb25-r34/
Dunno if there is a set to suit your application or not but there were pretty cheap compared to what i ended up with.... Couldnt be bothered reading or searching for you but try and see if it points you in the right direction?
I'd go a deatschwerks fuel pump over a walbro... any day.
Don't use efi hose for e85- you need something teflon lined/rated for alcohol.
For the extra money, I still choose ID injectors over the standard bosch items.
J.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
