  • Replies 94
ok i changed the duty on the boost controller, was testing it in 3rd gear, crusing on 3000rpm and then flooring it to 4000rpm, managed to get upto 1.1bar, i think this must be getting close to normal?
  • 1 month later...
im back baby!!! lol.... :woot:
just tuned with some flex fuel today and i think the gtx has earned its place under the bonnet finally... 20psi by 4000rpm, thats what i was after so happy finally, idle is smooth too now
added upto 6degree of timing all over the map and was mind boggling how good the flex fuel has made the setup.. even tuner was amazed.. on the drive back to the shop it easily fried 2nd , more like a burnout in second and third pulled so hard it was getting frightening lol.... :laugh:
320kw with flex fuel on 16psi , i think that might makes the gtx not too shabby...it spikes early but it is 16psi that makes that power unless im reading it wrong. It could have done bit more but with stock bottem end was not wanting to lean on things too much.. so im really happy with this result, no more than 20 knock on the power fc so is very safe too...
anyway, what do you guys think.. is this dyno respectable? do you think this dyno justifies the gtx or would the gt of been even better??? :happy:
320kw dyno printout 22222
Edited by SliverS2
it was from caltex so ill just fill up from caltex , theres 7 servo's within 30min drive so hopefully they are all similar ethanol content, tuner said to keep an eye on the knock level and he can adjust the mixture if theres any knock issues, so far its very low knock... dam this fuel smells good.. mm :yes:
320 @ 16psi is nice :)
screw 25psi into that bastard and see what it will do. Im guessing 350 is not out of the question
yeah i know, ill leave that to someone else lol... i just wanna enjoy driving it for a while, only been driven a few times in the last 8months..
im still giggling at the drive home from the dyno... lol .. this is how these cars should be.. frying the tyres up in second easy.. :yes:
yeah i think 320kw with stock engine is enough for me, and 16psi must be very safe so it should last a while hopefully... its 20psi in the midrange so im not missing out on too much i dont think..
very happy with it yeah... even idles smoother now and not jerky, very smooth and comes on boost alot better... :yes:
It looks pretty good now and it is great to hear you are happy with it. It's great when you finally get your car to its potential. It sounds like some suspension changes and tyres are in order.
I reckon a GT would have been a better performer by coming on earlier and would easily make that power level with E85.
I have my old GT3040 sitting in the garage and they seem to be pretty much the same as a GTX3076 but it just needs to find a home and some E85 to prove or disprove it.
At least the GTX compressor would be in the middle of it's efficiency, plenty more in it though. I got 350kw at 25psi to give you some idea of it's potential. I wouldn't be surprised if there was 400kw in it on a perfect setup.
thanks for the replies,
It would definitely hit atleast 350kw i think, but i think for my budget and for a street car it is at a point of being just a nice package, im not sure bout fitting better tyres yet, seems like too much fun to fry them up at will, i guess if you were being picky and wanted perfection, the gt would of shifted the power band to the left a bit but its done now..
when i bought the car with 200kw, it sounded doughy and lazy like alot of them you see on the road, now it clearly sounds unique and has a strong and angry note to it.. even just light throttle letting the revs climb , it sounds like dog flarring its teeth... :yes:
thanks mate.. would of been a bit lost without your DIY top feed thread... :thumbsup:
dont know if gtx is the way to go though, lol... that extra 500rpm or so response that a gt might give would be a good improvement..
Its internal gate that's the beauty..the amount. Of messin about I have gone through to make my kando fit and its struggling after 300kws..this is a much easier option..
But hey, I like to keep my local fabricators busy. ;)
    • Welcome to !
    • As I've said elsewhere, I am using the stock intercooler piping path in the engine bay, and a return flow cooler, and making ~250 rwkW (without any effort put into trying to turn it up past there just yet) and expect to be able to make some more, and frankly, I would be perfectly happy with 260-270rwKW. This is peak road Skyline usability territory. You go past there and, sure, the car will snap necks more when it's on boost, but it will also break shit all the time, cost a (even larger) fortune in tyres, etc etc. Anyway, I also do not like the over-the-fan pipe path, and you don't have to do it.
    • I see, honestly I’m not too fussed about the looks. The only reason to go plenum is to make the piping easier instead of the classic over the rad etc.
    • Not easy to quantify wrt something like how many fractions of a second slower it would be over 0-100. But given that a 250-300rwkW car is able to do that launch sprint in 5-6 sec (and faster with appropriate tyres, and surface)..... giving up as much as a second would feel like torture. A ~450HP capable turbo is not going to make lots of boost in the 2000-3000 rpm range. So, whilst with some boost on hand it will be faster accelerating in that rev range than your engine currently is NA, it will not feel like a fast car until the boost is solidly in. You know what your car feels like right now when you open it up at 2000rpm. if you've ever been in an actual fast car, you will appreciate that the NARB25 is.... not exciting. Well, add some boost and it will be better. But shorten the intake runners and it might not be better at all. It might come out better, but it could end up feeling the same. For me, it's not the 0-X km/h sprints that matter. It is easy to fry the tyres with anything over 200 rwkW. You can't use all the power available in 1st and 2nd anyway, you have to modulate the throttle. What matters is how the car reacts when you're driving in traffic in 4th or 5th and have maybe 2000 rpm on board, and you want/need to add some speed quickly, and don't have time for the downshift. It won't make boost, it will be all NA (at the speeds we're talking about - remember how fast you're going at 2000 in 4th! and don't plan on breaking the limit by too much.) So giving away NA torque is not what I would consider practical for a street car. And retaining that NA torque builds boost faster which makes the car faster. The flashy plenum is not actually better, unless you're looking at a track car where you can keep it on the boil all the time.
    • So how much difference does it make you think? Like 1 second in the 0-100?  I was have smaller turbo so hopefully that spools quick GTX2871.  currently it’s NA so you can imagine pretty slow, but I do want fast accusation a little as there’s not many places I’ll be driving where I go over 80 even near me. So 0-60 and 0-80 targets
