Michael,
I actually believe (rightly or wrongly) that Luke may have source 2 (of which he'd bought 1 himself) just in the past couple few days.
I don't even know what thermostat I have.
Nismo charges a lot for their spark plugs > wonder if they're worth it?
Most of the Nismo items I have, were sourced through SAU - yes, right here!
Actually one of the coolest things I saw at superautobacs was the motul nismo oil...and in bulk amounts.....
Aswell as the z tune, 370z demo car and the latest nismo GTR race car lol....but all my pics giot accidently wiped when my camera stuffed up
Michael,
Interesting, not sure who luke is though lol.
Nismo spark plugs I believe are exactly the same as one of the normal NGK's. They just have a different screen print.
My turn my turn :)
Nismo cluster
Nismo MFD
scuff plates (almost nismo)
nismo front and side indicators
nismo side skirt extensions
nismo b pillar garnish
nismo front upper arm bushes
nismo engine mounts
nismo GMAX twin plate
nismo cat converter
Nismo fuel pump
nismo injectors
nismo AFM's
nismo oil air seperator
nismo oil cap
nismo radiator cap
Nismo goodness!!!!!
post-12712-0-76234200-1338754517_thumb.jpgpost-12712-0-95055300-1338754523_thumb.jpgpost-12712-0-71242600-1338754527_thumb.jpg
post-12712-0-91705800-1338754531_thumb.jpgpost-12712-0-86098700-1338754535_thumb.jpgpost-12712-0-76852700-1338754539_thumb.jpgpost-12712-0-29372100-1338754546_thumb.jpgpost-12712-0-36877100-1338754551_thumb.jpg
Fitting these goodies was half the fun in some cases, and they do add that little extra to the base setup. Great having pretty much oem nismo factory parts too as they will go the distance.
  • Like 1
Thank you again Dave for some scintillating Pics.
That list of "purposeful" items Sean + your mechanical brain -> great Nismo Car driven by a Nismo-Nut :)
Another "purposeful" item in readiness to go in will be a G-Max twin plate
^^That knob is a fake Nismo knob.
It was just a picture from the net :rolleyes: ; didn't notice until I'd posted it that the knob is polished not satin finish.
Mine was the real thing.
Anyway, back to Nismo...
Edited by Daleo
How are you "Finding Nismo" products in general?
Some are useful - others cosmetic
Some are oldies but goodies - some are discontinued
Some are well designed - some are designed better
Would you like to...
1) Post a Pic of a favourite that you own?
2) Post a Pic of a let-down?
3) Caption the Pic with a comment?
I have Nismo Front Bar and Side Skirts:
(But no bonnet / boot lip spoiler).
The Nismo kit is subtle and clean and tops off the R32 GTR nicely.
Also an Oil Cap:
Add a nice touch to the engine bay and you cannot over tighten the cap.
Had a Nismo Slave Cylinder:
Had to be replaced and now have a Nissan one.
So want that Radiator Cap!
Gimme gimme gimme!!! :D
That will be one of my next Nismo items I want.
I have a few NISMO items on mine.
NISMO strut brace
NISMO white centre gauges
And at night time. Love these things when lit up
NISMO turbo back exhaust
And NISMO sideskirts
Did have a few more pics of the exhaust but cannot seem to find them
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
