You just buy them, no exchange needed. Guess they go round stealing them off old wrecks and old Oem stock!
Can't work out why one side of the bar is braced extra, but guess they know.
They're still in production. They wouldn't use used parts.
All parts genuine
Currently own:
Lmgt4 white 18x7.5 +30
Lmgt4 bronze 18x9 +22
Lmgt4 silver 18x9.5 +12
Black: still to collect 18x10.5 +15
Nismo design key uncut - 8 point
Nismo horn button
Nismo gt shift knobs rubber and titanium
Nismo r tune front bar fiberglass - s15
Nismo 740cc injectors x4
Nismo 555cc injectors x6
Nismo gt LSD pro tt model
Nismo floor mats 5 piece set
Nismo speedo 260km/hr
Nismo timing belt
Nismo main and conrod bearing sets
Nismo number plate surround
Nismo wheel nuts
Nismo valve caps
Nismo horns (came on s15 lol)
Nismo t shirts x3
Plus a few other bits
Sold:
2 of those horrible duracon gear knobs
Fuel filler cover that was junk
One set of lm gt3 in silver 17x7.5 17x8.5
Lost:
nismo lanyard
Nismo hat
Would like to buy
Lm gt4 in 19 inch 9.5 or 10.5 width
Nismo inlet manifold
Nismo outlet pipes in carbon from r34 clubman spec, surely they will produce these
Nismo suppercoppermix twin plate c spec
Nismo intercooler and hard pipes (just because)
Edited by Gts30t
Wish whoever left one spam, now my comment looks out of place and weird :/
Lol ^^
If I ever sell my GTR, I'd like to think that the Nismo key goes with it, as an uncut blank.
They're badges above and below the key. They're made by Nissan, but I can't find the Part#.
  • 1 month later...
  • 1 month later...
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
