Very nice and clean, seen it in person too :P more pics pls :)
Half a inch more. I reckon it'd be close.
Of course they are lighter lol, hey bueller we need a thread with more pics of your sweet ride mate. Don't leave us hanging :)
You'd hope they're lighter as they cost about 150000 yen odd new per wheel back when they were produced from memory, double or close to double the cost of the lmgt-4. Not sure what the gt500s cost though.
More pics here or in another thread?
A few -
post-135234-0-09299700-1412675876_thumb.jpgpost-135234-0-49905300-1412675917_thumb.jpgpost-135234-0-09267800-1412675902_thumb.jpg
  • Like 1
Well,,, just read through the whole thread,,,very impressive purchases boys and girls. We are all keeping them in a job.
I was asked by Zebra once why I had a Nismo sticker (chinese copy) on my windsreen when possibly I didn't actually have any nismo gear on the race car. Well there's not that much to buy for a poor old R33 GTS-T but I am doing my best.
Nismo Speedo
Nismo Key
Nismo GTR Fuel Pressure Regulator
Nismo Front Lower Control Arms (Oh wait I bent one racing)
Nismo Rear Upper and Lower Control Arms
Nismo clutch and brake mounting Brackets (not really but nismo cheated by just welding more points)
Nismo Thermostat
Nismo 555 Injectors
Melinda was a bit taken by all the cool stuff Lander Toyota had bought into skippy land many many years ago and bought these 2 items,,,. We still have the receipts somewhere,,,pity we didn't keep the packaging..
Cheers
Neil.
A few -
Close ups would be good including stickers. :)
When and where did u pick them up from Terry? Nice :)
'Twas I Marko who gave you a heads up on this set being on that BCNR33 F/S remember? I said you might ask Kamikaze... if he might separate the wheels from his car that's on offer. Then I noticed you'd ordered new ones so I stepped in afterwards.
Ahhh yes tbh I didn't instigate that path as I couldn't go past the wheels i got being full monoblock forged and less than 8kg superlight :) I'm happy
Besides that, white wheels on silver meh whereas on your white gtr would be nice...are they 18x9.5 Terry?
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
    • I can donate $100 to your upgrade fund. So long as you can donate the IC7 my way....
    • I'd love a Haltech ECU, and Haltech 10 dash. Was having a chat with Rob and Andy @ Haltech when Rob put one in his MR2. First one I'm kind of interested in too, as you can dim it RIGHT down. Andy was saying bright dashes is one of his peeves too!
