So I just got back from nismo factory today, prepare your wallets...
Two up coming parts to be released soon.
R32/34 full carbon fiber air box
45B38EEC-6936-402D-A4DB-C5510E43327E_zps
R32/33/34 carbon fiber turbo pipes
67C9EDF1-9CC0-4F4E-A1C8-80010C2C889C_zps
They wouldn't tell us how much no matter how many first born sons I offered them.
Also I'm finishing up my interior, when the rain lets up here I'll get some pictures of the nismo seat covers for the r32.
Edited by slowridn73
  • Like 6
I want them carbon turbo pipes.......happy sell child to do it
I am for sure interested. Its good for the people who like a stock like appearance but also like that "customization" feel. I can almost guarantee it will cost way more than actual benefits. But that is really all up to the purchasers opinion. I personally like it, even if it does cost (im going to guess lol) 3k total package lol.
Also, slowridn73, can't you technically only have 1 first born son lolol?
Edited by JTCC
The retain a little more heat due to the poly "leather" but it grips better than stock. It you can get over a few imperfections in the fitment such as the middle not sitting flush with the actual seats then they are nice. Everyone that's looked at them loved them.
    • I personally would go with cutting out the rubber. Then deal with getting sleeve off separately. Rubber can be painful to cut, it loves to jam up cutting tools. I normally have success with drill bits, deburr bits, angle grinders, jigsaw, reciprocating saw, and never forget... fire. Obviously different tools won't work in all locations you're trying to work with, and you need to be comfortable with each. You personally may be happy slowly slicing it out with a razor blade, if you are, go for it with one too! Feel free to wait for others to weigh in also on their thoughts.
    • So ... I got everything disconnected and started dropping the frame. Three of the four mounts started to come down but the fourth one (the one with the nut that gave me all the trouble) won't budge. The inner metal sleeve stays up tight against the chassis rail although the outer part of the mount drops a bit (and can be levered quite a lot more) but it's just stretching the rubber bushing. So I reckon there's some serious corrosion inside the inner sleeve and holding it tight to the lug at the top of the bolt. Tried everything I can think of so far: penetrating oil, whacking the top of the sleeve to vibrate it and wedge a screwdriver blade in there. I also tried to turn the inner sleeve a bit by hitting it with a chisel at the bottom. It's stuck solid. What do you think about cutting the rubber with a blade so I can drop the subframe around it anyway. Then worry about getting the inner sleeve off after? Will that work? Is it gonna give me even more problems?
    • Steam valve seals are usually responsible for cold start smoke, it goes away once engine warmed up. Disconnect it let engine breathers and let it breath freely, see if problem goes away after a short drive. Also check to make sure engine oil drain pipe is not blocked or kinked.
    • Haha thanks! Yea I'm moving over from 2x 1000cc jets pre throttle over to 6x 190cc direct port jets and 1x 500cc pre throttle jet.  Direct port comes with all the advantages you would expect, except that pre throttle does cool down IAT'S more. That's why my direct port nozzle placement is closest to the plenum as possible in the runners to allow the air more time to cool before being sucked in. I'm also putting that one 500cc pre throttle jet to help with more cooling. It's a hybrid system. There's a lot more advantages to moving over to a PWM solenoid with a constant pressure system vs my old PWM pump setup, but I'll get more into that once I'm done converting everything over. The ricer in me is excited to see SS tubing all over my manifold though!
    • Very cool, see what I did there? 🥲 Wild WMI setup, first I've seen where it's on each cylinder runner, usually I see a single jet pre throttle.
