Yeah cheers and sorry for jumping in on your discussion but I love the look of that pipe.
A few people on SAU have them (gts25, therealsandybang) but not sure it is a Weldina. I asked gts25 but he didn't think so:
http://www.sau.com.au/forums/index.php?/topic/119761-R32-Pix-Only#entry7545869
its just a nismo, not a weldina. I believe the weldina exhaust will have a weldina tag on them somewhere. I think the muffler tip will say "NE1 weldina". Its a dual 60mm that collects into a 80m. The nismo carbon pictured is a cool item for the nismo freak if you want a non aggressive stainless steel exhaust. Me personally, always been a titanium kind of guy.
  • 3 weeks later...
Im pretty sure you can still buy those strut bars new....for a lot cheaper. At least I know you can for r32. Unless they don't offer that old nismo style plate. I know you have a omori factory or nismo option.
Finally picked up the last piece of old school nismo knick knacks.
Finish off my set of period correctness. I almost feel bad opening these lol. I will use everything but the fashion lighter. To many of those opened already.
Edited by JTCC
  • Like 1
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
