SAU.NSW will be doing a cruise JTCC from Windsor to Singleton (tomorrow) along a lengthy road called Putty Road.
At the Singleton end (located on Google Maps), there are lots of twisties; so I'm looking forward to seeing how balanced the car is.
There's no geometric difference in this wishbone set that I installed 2 months ago...
Wishbone%20Links%20Rear-1_zps49l6ej6f.jp
but the tensile strength is different I'm sure. Doing so much in such a short period without me taking out the car for long stretches - but only for short hill climbs - is testing my memory a bit I must admit.
The nuances of each add-on are probably going to be somewhat imperceptible.
  • Like 1
Yea I have had my eye on the nismo arms and circuit link kit also. Just to refresh the stock suspension. I'm sure the stiffer bushings will give the car a more solid feel. Especially replacing 25 year old factory bushings lol. From what I have read, the sway bars make the biggest change in getting rid of the factory understeer feel. Which I'm no race drive lol, but I think my stockish GTR with HKS coils and advan rubber already handles like a dream lol. Makes me really wonder what it feels like with something decently modified. Have fun on the cruise! Its summer down their.....we got winter lol. But it was 70 yesterday :)
  • Like 1
Has anyone seen or heard of a Nismo branded gearbox shroud thing that sits around the top of the shifter to prevent oil coming out the top?
Someone told me about it but I haven't seen it or anything like it for sale anywhere.
  • Like 1
  • 4 weeks later...
Most likely. They go for around $200-250 depending on condition.
I don't know why the aussie market is so over priced lol. I just sold 2 of mine for 100 bucks USD (140 ish AUD). You can get these on yahoo japan all day for in the 7,000 to 10,000 yen range. The yellows are more rare and go for about $120ish USD (170 ish AUD). I think I will start selling parts to Australia lol. I have a lighter brand new in box never opened, wonder what you guys would pay for that lol. I've noticed you guys go crazy over nismo keys to. 8 points are higher priced than 10 points here. Can find 10 points on yahoo japan all the time for like $250 USD or so. 8 points seem to be disappearing quite fast, brings a higher price.
A few nismo bits over the last few months for the gtr
Nismo carbon fiber spoiler blade
Nismo carbon fiber room mirror
Nismo omori factory carbon cooling plate
Nismo fashion lighter
Nismo adjustable fpr
Nismo braided brake lines
Nismo braided clutch line
Nismo transmission mount
On order
Nismo intercooler pipes
Nismo engine mounts
Nismo panel air filter
  • Like 2
I recently pick up another Nismo Key to add to the collection at an affordable price.
There are more available from the Sydney seller in Kirrawee on eBay
http://www.ebay.com.au/itm/Nismo-Key-Suit-Skyline-Gtr-300Zx-Silvia-Datsun-Owners-/281930600587?
Pretty sure you'll find those are non-genuine.
It also looks identical to http://www.ebay.com.au/itm/Nismo-Key-Blank-Nissan-Skyline-GTR-Silvia-R32-R33-S13-S14-R31-/301863018274?hash=item4648701f22:g:CPsAAOSwnLdWsBrS ... which is also at a much lower price.
Nismo Key Blanks
These have been designed based off the original keys and updated with the current Nismo logo
These reproduction keys are limited production so get in fast once they are gone they are gone.
  • Like 1
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
