Hi All,
We have a new toy and it's name is DynoDynamics!!
Ice Performance has now had it's big red 2WD reading machine delivered and it's ready to rumble.
We are planning a Big Dyno day/BBQ very soon, so will keep you posted.
Also if any of you guys want to plan a day yourselves just let us know.
Call (03) 95127591 for any queries or bookings and join the Ice Performance Pyramid of Power!!!!
https://www.sau.com.au/forums/topic/40171-the-dyno-is-in/
Hate to be a grumpy bum, but wouldn't a 4WD dyno have been a good investment.
I mean it will take ages for a dyno day with lots of GT-Rs...
i think it was a costing issue
4wd costs a LOT more.
and when you can drop a driveshaft in a matter on mins to make a GTR rwd, then does it matter?
https://www.sau.com.au/forums/topic/40171-the-dyno-is-in/#findComment-823206
Well do ICE take out the driveshafts for free?
If it takes 15 minutes to take a driveshaft out (including getting it on and off the hoist) moving cars, doing the next car... it only takes 4 GT-Rs to waste an hour of their time.
I guess it depends how many 4WD cars would turn up to a SAU dyno day.
https://www.sau.com.au/forums/topic/40171-the-dyno-is-in/#findComment-823276
God, this is bloody old news Dave.
Get up with the times
Ash, don't get smart or we'll charge you double!!
A 4WD dyno costs double a 2WD dyno. Takes a lot of GTRs, Evos and STis to make up the outlay.
If we do need a 4WD dyno, we have other places we can take the cars.
https://www.sau.com.au/forums/topic/40171-the-dyno-is-in/#findComment-823307
maybe we should make an event out of it. SAU/Fangartist Dyno day anyone? Would be bloody awesome to see the fangers go on the dynos again... but make matlowth go last... he has a tendancy to break/blow up dynos.
https://www.sau.com.au/forums/topic/40171-the-dyno-is-in/#findComment-823387
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
