Your Favourite Restaurant's In Sydney
GTR32X
 Share
decided to go to HC Hawa (formerly Awafi) in Granville. Must say, their chicken is much better than El Jannahs, will definitely be going back.
and the garlic sauce? is that the one down the road from EJs?
on the money there, and the chicken isn't as dry or salty.. not to mention you can eat in their cafe next door that does CAMPOS coffees.. super win :)
ended up going on sunday.
have to say their garlic sauce isn't as flavoursome as EJ/Hot rocks and so, falls to third place out of the 3, but their chicken is better than EJs by far, similar to Hot rocks. Chips, prob depends on the person making them but mine weren't crunchy enough nor fresh piping hot...both hot rocks and EJs win in this respect because you always get fresh hot chips. but the garlic sauce here is way cheaper than other stores!
overall pretty good. OH and their pickles are not super super salty, they were actually refreshing to put in the wrap with chicken for once!
The platters are definitely better at HC Hawa. Another one to try (not sure if it's been mentioned already) is La Mono in Merrylands. Cleaner than either HC Hawa and EJ, and you don't need to worry about getting stabbed/shanked/mugged (kind of ironic since La Mono is in Merrylands, lol). Keep in mind they are a bit more expensive than HC Hawa and EJ.
Another place I have heard of, but have not yet tried, is the Middle Feast. Apparently it's a new place. If anyone has been there I'd love to hear your thoughts.
Degustation
Exxy but great eating when your pockets are full and you're ready to celebrate.
The following are all exquisite but my rankings are...
1) Quay at Circular Quay
2) Tetsuya at Sydney
3) Waqu at Crows Nest
4) Sabatini's on Golden Princess Liner - sorry about that.
5) Ashcroft at Blackheath
6) Como at Blaxland
Yup > Best Thai yet!
* Barramundi in lime and lemongrass 9/10
* Prawns in red curry sauce 8/10
* Crisp Pork Belly 8.5/10
* Soft shell crab with mango salad 8/10
Hint:- Ask for a side bowl of coriander for sprinkling
Thanks Kat :)
I once had a compulsive eating patient who said, "I don't want to go to heaven unless they have pork crackle up there!" hehe...
Crispy Pork Belly at Chedi yes - recommend!
Quan ( one of the partners ) was funny.
He tried to convince us that we'd ordered too much > cut down on the order Lol
I love degustations so much cos I'm a big fan of eating lots of little things rather than one big plate of the same thing!
With all the matched wines is THE BEST :yes:
I've not done a degustation since I'm a bit fussy with wine and I fear some of it (especially the reds) are a bit lost on me.
My fave restaurant in Canberra does one though and they also do some pretty epic tapas. I usually have a few wines and ask the owner to "Bring me food" and he just brings out awesomeness. I've been going there a while, he lets me behind the bar sometimes to serve my own drinks :D
 Share
    • Opened up the cluster to inspect the gauge itself for signs of damage and it looks good. Got curious since that needle doesn't go back to a "neutral" position by itself (it stays in the same position when ignition is off. so I manually moved it to 1/2. Connected it back, turned on the ignition and the needle started moving up! Not sure what's up with that but before that the needle was way down below empty like fully south west. There's always a chance that the needle moved slightly the first time I tried and I didn't notice because of how slowly it moves and how far it was from the markings. I don't know if the current needle position is accurate so I'll fill it up and see where that brings it. I guess I'll try to adjust it manually if it doesn't get to F. Looks like the needle position is relative and not absolute? Thanks all for your help and patience!
    • You're confusing two different responders and more than one issue. The stock Neo ECU boost sensor is used by the ECU for protection purposes. It is essentially only an overboost sensor. It is not used for determining engine load for fuelling or ignition purposes. That task falls solely to the AFM. Any aftermarket ECU that either has an onboard MAP sensor or a plug in one, will use the MAP sensor as the primary load sensor. Or I should perhaps say "can", rather than "will", because some of them have the option of using other primary load sensors. That MAP sensor is not for the same function as the stock Neo boost sensor. The reason I recommended against a plug and play ECU is that they are intended to run a particular engine and usually in the car that the particular engine came in. So, if you have a transplanted engine in a different car, with some parts of the original missing (such as the boost sensor, for example) and therefore likely non-standardness of the loom and its insertion into the car's loom, then it is very likely that you will run into the same problems with needing to fix up wiring to make it work that you would with the stock ECU. And, if doing so for the stock ECU is enough of an obstacle that you start considering a standalone plugin as a solution, it should become clear that the plugin is quite possibly not the solution you'd hope it to be. It would just lead to more of the same type of problem solving work to get it going. In the above paragraph and in my earlier post, the lack of the boost sensor is not critical. It was just used as an example of something that we knew you did not have right, such that the stock ECU would not work. I took that as an indicator of a reasonable probability that there were other related problems hiding there.
    • I can think of two places in my city of <1.5million population that specialise in automotive instrument repairs.Unless you're out in the wilds of Quebec, you have 3 major Canadian and 3 major US cities within the same distance as the single nearest city to mine. Surely there is somewhere you could send it.
    • I never cared for twins but whenever these conversations came up, I always presumed the higher number represented a larger turbo. Learn something new everyday.
    • Interesting, I've never seen a failure like that before but with the age of these cars and the general questionable-ness of all kinds of parts these days you can't rule anything out I suppose. Boost leak testing the boost control system would've revealed this though.
