Rabster The Outlaw Posted June 10, 2012 Share Posted June 10, 2012 Ok so as boosst let the cat out the bag before i had got the car up to scratch here is my new project. the only real reason for the car is i cant do a huge amount to my 350z as its pretty much the car i want it to be so i found this beauty.... Her spec is as follows 1996 Series 1 Stagea Greddy E-Manage Greddy FMIC Turbosmart e-Boost 2 FCD HKS Induction Garret T30 Turbo Blitz Downpipe HKS Decat Torque Flow Back Box Tein Coilovers 4pot front callipers Grooved & Dimpled Discs Twin Pot Rear Callipers Poly Bushed Uprate Susspension Arms Tein Adjustable Pillow Ball Tension Arms Series 2 Rear Lights Tinted Rear & Back Windows 18" Wolfrace Wheels DVD Headunit Infinty Speakers Clifford Concept 650 alarm Remote start Prosport AFR Prosport EGT Prosport Boost Link to comment https://www.sau.com.au/forums/topic/402235-my-nissan-stagea-from-purchase-till/ Share on other sites More sharing options...
Rabster The Outlaw Posted June 10, 2012 Author Share Posted June 10, 2012 So i started the conversion on thursday morning so here are the pics in the morning Kit positioned Headlights cut into place Test bolt up Semi finished front end etc I can confirm that you can make the factory bonnet catch work you need to drag forward about 2 inches i used stud and nuts to do this however the bonnet catch is quite a stiff ****** so needs to be braced from below or it wont shut and latch also factory hinges with r34 tops dont work for the masa bonnet, it sits far to low and has to be spaced (temporarily) 13 x m8 washers per side to even come close plus the actualt hinge is to far over and has also been spaced to even come close to the mounting holes on the bonnet........ Link to comment https://www.sau.com.au/forums/topic/402235-my-nissan-stagea-from-purchase-till/#findComment-6392992 Share on other sites More sharing options...
Rabster The Outlaw Posted June 10, 2012 Author Share Posted June 10, 2012 so few more pics now As you can see the bonnet still doesnt line up right i think this is due to the fact there are to many variables on the bonnet line up so need to solve this before i can get the lines right. thought this wont stop me getting the car Wrapped ASAP alll thats left now is the rear Splitter to fit but this requires some modification and it was raining lol Link to comment https://www.sau.com.au/forums/topic/402235-my-nissan-stagea-from-purchase-till/#findComment-6392993 Share on other sites More sharing options...
Rabster The Outlaw Posted June 10, 2012 Author Share Posted June 10, 2012 so turned out i was missing a headlight bracket so had to order the drivers side one of these whilst i was at it i got the GTR bonnet latch re-locator and GTR hinges i didndnt fancy cutting them apart so i for now have made wood spacers namely due to the fact i was dong this an hour from my metal working facilitys and i want to get the exact height it needs to be so far sitting at 35mm height change whilst still using the R34 GTR hinges complete so with the car now lined up properly we could see the differences in the dimensions of the kit and i wasn't happy so out came the fibreglass and filler etc and here we go gap before fiber glass added Filler added so with the kit now lined up propperly time to get on with the prep to paint we did flat it all down etc and started with the filler primer Unfortunatly there had been some touch up work done and the paint even though flatted reacted badly with the primer so had to be sanded down again and treated with barcoat to plat it safe i did the whole front of the car in it even inside the shuts New coat of primer applied No reaction so carried on so now waititng for that to fully arden for a few days before any base coat is applied but here is the workshop/ Spray shop Link to comment https://www.sau.com.au/forums/topic/402235-my-nissan-stagea-from-purchase-till/#findComment-6392994 Share on other sites More sharing options...
Rabster The Outlaw Posted June 10, 2012 Author Share Posted June 10, 2012 Ok so yesterday I had the day off work so after a early start to get the last few bits do e it was time to paint started with the skirts After a few coats we left those to harden and after about 30min in the polly tunnel it was time for the bumper Again few coats later and lunch time for the wings We deliberately sprayed onto the bonnet to get a thick coat on the edges as we're expecting as with most cars that to be the points that could get damaged easy So... Also did the fuel filler car and the bump strips of the new wings Will do another few overall coats this morning then start with the lacquer depending on how quick it all goes off will depend on if it drives away this Sunday or not...... Stay tuned lol Link to comment https://www.sau.com.au/forums/topic/402235-my-nissan-stagea-from-purchase-till/#findComment-6392996 Share on other sites More sharing options...
Rabster The Outlaw Posted June 10, 2012 Author Share Posted June 10, 2012 Ok so end of another day which started off not do well there had been a reaction over night to something we suspect a mixture of 2thinners maybe the culprit so had to sand the wing back again few more costs then again untill no reaction was left didn't fancy going all the way back to Barcoat as thats lots of work etc So once this was do e we carried on few more dustings on the rest of the car then a light rub down and lacquer time now this stuff goes off quick dependant on mixture levels do we had what we thought was a 25min window per load turned out due to mixture and heat that it was a 10- 15 min window lol So after 4 passes this is the state Link to comment https://www.sau.com.au/forums/topic/402235-my-nissan-stagea-from-purchase-till/#findComment-6392997 Share on other sites More sharing options...
Rabster The Outlaw Posted June 10, 2012 Author Share Posted June 10, 2012 ok so thats the second weekend over with an still its not on the road but we do have significant progress there was a few runs so we gave everything a quick rub down and then re lacquered so the moment you have been waiting for well i hope you have anyway lol The body work unfortunately has orange peel i think to do with a mixture of things mainly the heat it got to in the room during the spraying rather than after where you bake it on so this means i have to flat the orrange peel down to get my glass finish i want so that's next weekend sorted here is the comparison what are your views anyone had orange peel from spaying before etc..... Link to comment https://www.sau.com.au/forums/topic/402235-my-nissan-stagea-from-purchase-till/#findComment-6392999 Share on other sites More sharing options...
Rabster The Outlaw Posted June 10, 2012 Author Share Posted June 10, 2012 Ok so I must be mad but spent the day outside in the rain with the wet and dry paper sanding the orange peel out so we now look like this This is how it did look If the rain will do ne tomorrow I will hit the car with the g220 cutting compound then polish it ready for the ace cafe next week...... Link to comment https://www.sau.com.au/forums/topic/402235-my-nissan-stagea-from-purchase-till/#findComment-6393001 Share on other sites More sharing options...
Rabster The Outlaw Posted June 10, 2012 Author Share Posted June 10, 2012 Well we have success but was without its moments, if anyone attempts painting the car again dont try and use the Meguiers G220 to get out the Orrange peel or even the aftermareth of using 1000 - 2000 gritt paper as its not man enough. i found this the hard way so had to go and buy a new Sander/polisher but once i did wow what a difference cut through the scratches alot easier and brought the car up to a nice shine so here is the finished article prior to leaving the Booth today So i drove it back to the ranch and gave it some love so after a clean and a hit with Poor boys Black Hole we look like this Link to comment https://www.sau.com.au/forums/topic/402235-my-nissan-stagea-from-purchase-till/#findComment-6393005 Share on other sites More sharing options...
Rabster The Outlaw Posted June 10, 2012 Author Share Posted June 10, 2012 So here we go this was the paint match on saturday So i tried to polish but no such luck due to being the wrong paint on the rest of the car so on sunday afternoon i started masking up and monday morning / Lunchtime it got bar-coated sanded the high spots of then hit it with colour So after 3 and a bit coats of paint It was time to leave it over night the roof isnt right and requires a further coat as its so big and such a pain to paint its got alot of imperfections but im hoping that i can get lacquer on it tonight and maybe tomorrow sand the lacquer again and hit another coat on keep your eyes open for more updates lol Link to comment https://www.sau.com.au/forums/topic/402235-my-nissan-stagea-from-purchase-till/#findComment-6393007 Share on other sites More sharing options...
Rabster The Outlaw Posted June 10, 2012 Author Share Posted June 10, 2012 New Paint match Complete car Link to comment https://www.sau.com.au/forums/topic/402235-my-nissan-stagea-from-purchase-till/#findComment-6393008 Share on other sites More sharing options...
scotty nm35 Posted June 10, 2012 Share Posted June 10, 2012 Very nice, I love the spray booth. Link to comment https://www.sau.com.au/forums/topic/402235-my-nissan-stagea-from-purchase-till/#findComment-6393027 Share on other sites More sharing options...
KiwiRS4T Posted June 10, 2012 Share Posted June 10, 2012 Wow good job! How long fron start to finish? Link to comment https://www.sau.com.au/forums/topic/402235-my-nissan-stagea-from-purchase-till/#findComment-6393038 Share on other sites More sharing options...
Zorro Posted June 10, 2012 Share Posted June 10, 2012 Nice work, car looks great! Link to comment https://www.sau.com.au/forums/topic/402235-my-nissan-stagea-from-purchase-till/#findComment-6393064 Share on other sites More sharing options...
Rabster The Outlaw Posted June 10, 2012 Author Share Posted June 10, 2012 all in all it was about 7 weeks but this did allow for me not working on it during the week as it was at my weekend house (big garden as you can see) Most of the time was spent on the front end and side skirts preparing for paint etc the rest of the car was mainly a blow over which was about 2 weeks work Link to comment https://www.sau.com.au/forums/topic/402235-my-nissan-stagea-from-purchase-till/#findComment-6393097 Share on other sites More sharing options...
wolverine Posted June 10, 2012 Share Posted June 10, 2012 I wish I had the time, skills and patience to do what you have done. Needs more power. Link to comment https://www.sau.com.au/forums/topic/402235-my-nissan-stagea-from-purchase-till/#findComment-6393193 Share on other sites More sharing options...
Duncan Posted June 10, 2012 Share Posted June 10, 2012 good work, goes to show how much damn work there is in a "bolt on" r34 front end too. Link to comment https://www.sau.com.au/forums/topic/402235-my-nissan-stagea-from-purchase-till/#findComment-6393429 Share on other sites More sharing options...
adey88 Posted June 10, 2012 Share Posted June 10, 2012 Wow you dont waste any time huh? That was about a years worth of thread posted in 2 days!! Turned out beautiful, i like the S2 rear lights too! Seems to be a few stunner stageas from the UK.... any further plans for the car? Link to comment https://www.sau.com.au/forums/topic/402235-my-nissan-stagea-from-purchase-till/#findComment-6393496 Share on other sites More sharing options...
66yostagea Posted June 11, 2012 Share Posted June 11, 2012 (edited) That is seriously good shit. Edited June 11, 2012 by 66yostagea Link to comment https://www.sau.com.au/forums/topic/402235-my-nissan-stagea-from-purchase-till/#findComment-6394357 Share on other sites More sharing options...
joe26f Posted June 11, 2012 Share Posted June 11, 2012 Love it Link to comment https://www.sau.com.au/forums/topic/402235-my-nissan-stagea-from-purchase-till/#findComment-6394445 Share on other sites More sharing options...
