Honestly guys what is wrong with people!! Is it people are jelous of what others have or is it simply they are d**kheads??
Ive had this current GTR a few months now and its already been badged once, and now i come out and it looks like some one has put the boot into my standard intercooler!!
Yes i was going to change it anyway but its not the point!! Now i have to find some cash straight away etc!!!
And what makes more more pissed off is if i was to catch them and punched one in the mouth id be the one in trouble!
Anyway, i havent the cash right now to splerge on a $1000 dollar intercooler...
And my car will be running between 350 and 400 kws after the next tune...
Would this item be ok for what im after?
http://www.justjap.com/store/product.php?productid=16930&cat=298&page=1
Or could i run a smaller core?
Or is there any other better options??
Yes ive searched the many topics and i dont want a standard one again. :angry: :angry: :angry: :angry: :angry:
https://www.sau.com.au/forums/topic/402447-rant-intercooler-question/
Can't have searched too hard, that cooler and others have been covered in many, many topics. Why not look in the RB26 dyno results thread and pick a cooler that people making similar power to what you want are using?
Also, cheap/reliable/fast - pick two, you will seldom find all three.
Well either spend the money to have a nice looking good intercooler or buy a second hand standard one for cheaper. Or get a just jap one for cheap
These are your options. Don't go getting angry when people offer you advice
The cheap cool looking aftermarket option that might run into problems
Or the proven one, that still remains cost effective to get polished (or just get a R34 one, they come silver...)
Seen CoolingPro items max out at just over 300rwkw, so be careful what you decide. You only have 2 options really, and 400rwkw and budget do not ever go well together.
  On 13/06/2012 at 6:24 AM, Adz2332 said:
Ah ok thats cool....
Doesnt the 34 cooler have a temp something on it that 33s dont have??
Yes, the BNR34 intercooler has a hole for the OEM temp sender in one of the end tanks, but its not to hard to block off.
I don't really see the point in probably paying more for a new china cooler that you dont know if it will be up to the task rather than picking up another standard one for cheaper but you know will handle the task no problems just for some extra shine. In my opinion unless you want to pay a decent price and go with a decent aftermarket cooler then stick with proven stock.
  On 13/06/2012 at 9:18 AM, v8tzr said:
Whats the max power u can push thru a standard 33 gtr cooler? Also at what power do intake pipes need changing ?
http://www.skylinesaustralia.com/forums/index.php?app=core&module=search&search_in=forums
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
