  • Replies 238
Posted Images
here it is, skip to around 5:50 for flameage
http://www.youtube.com/watch?v=PnMvr5p_juw&feature=plcp
Does anybody know why outside is so over exposed? im using a GoPro HD2.
I was thinking maybe theres too much black in the picture from the cabin for it. But i have know idea when it comes to filming...
Check to see if your metering on the GoPro is set to "Spot Metering," which is the small dot in the middle of a square. That way, it takes a light reading from just the centre of the image instead of the whole screen (Evaluative Metering). That might help, bet even then with a GoPro it can be hit and miss unless you have the LCD Backpak or can aim it almost spot-on out the windscreen.
It's trying to balance for the majority of the screen. Since most of your video is of the inside of the car it has gone for that. You can try repositioning it to see more out the window next time.
I don't know what settings they have, but you might also be able to make it work on the focal point, then all you need to do is get the outside of the car in the center of the screen for more magic. Either way, its 1 or the other really, if you get good outside, inside will be dark.
Looks awesome fun either way!!
+1 the orginal GoPro HD's came default average metering. I had to turn spot metering on. The down side is that the cabin will be much darker. But when shooting in a dark environment with bright outside you have to "tell" the device what you want to do. The "Dot" that Nick said is pretty much in the centre of the picture that is used to read how much light and therefore what exposure setting to use. When you aim it just be sure the centre of the frame goes out the windscreen.
If you have editing software you can usually bring down the exposure a bit as long as there's still a bit of detail (not washed out or all white). The colors and contrast won't be as good but will give a bit more detail.
Ok, cheers for the info guys. I'll gives that a try
What do you recommend for editing and uploading to youtube with Eric? I used the window's program but it came out pixelated in places and was quite a large file too I think (380m)
When editing I assume you mean just clipping - right? Streamclip (freebie) can do that and maintain the H.264 Mpeg4 codec the GoPro uses. It's only basic but will do clipping. Be sure to stay on an MPEG4 code - H.264 is best right now, or else xvid or divx. H.264 will produce the best looking video with the smallest size but may take longer to encode.
The GoPro in 50/60 frames progressive is ahead of the standards right now. There isn't really an Official standard that does that framerate in HD. Hence why I recommend streamclip if you just want to clip them down.
For full on video editing I use Corel VideoStudio Pro X. Does everything I need and more and only $120 on line.
For YouTube and Vimeo I usually create a 720P file in DivX format with a reasonable bitrate. Still a couple hundred megs for a few minutes but looks so much better now that everyone has big monitors and broadband.
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
