  • Replies 238
Posted Images
here it is, skip to around 5:50 for flameage
http://www.youtube.com/watch?v=PnMvr5p_juw&feature=plcp
Does anybody know why outside is so over exposed? im using a GoPro HD2.
I was thinking maybe theres too much black in the picture from the cabin for it. But i have know idea when it comes to filming...
Check to see if your metering on the GoPro is set to "Spot Metering," which is the small dot in the middle of a square. That way, it takes a light reading from just the centre of the image instead of the whole screen (Evaluative Metering). That might help, bet even then with a GoPro it can be hit and miss unless you have the LCD Backpak or can aim it almost spot-on out the windscreen.
It's trying to balance for the majority of the screen. Since most of your video is of the inside of the car it has gone for that. You can try repositioning it to see more out the window next time.
I don't know what settings they have, but you might also be able to make it work on the focal point, then all you need to do is get the outside of the car in the center of the screen for more magic. Either way, its 1 or the other really, if you get good outside, inside will be dark.
Looks awesome fun either way!!
+1 the orginal GoPro HD's came default average metering. I had to turn spot metering on. The down side is that the cabin will be much darker. But when shooting in a dark environment with bright outside you have to "tell" the device what you want to do. The "Dot" that Nick said is pretty much in the centre of the picture that is used to read how much light and therefore what exposure setting to use. When you aim it just be sure the centre of the frame goes out the windscreen.
If you have editing software you can usually bring down the exposure a bit as long as there's still a bit of detail (not washed out or all white). The colors and contrast won't be as good but will give a bit more detail.
Ok, cheers for the info guys. I'll gives that a try
What do you recommend for editing and uploading to youtube with Eric? I used the window's program but it came out pixelated in places and was quite a large file too I think (380m)
When editing I assume you mean just clipping - right? Streamclip (freebie) can do that and maintain the H.264 Mpeg4 codec the GoPro uses. It's only basic but will do clipping. Be sure to stay on an MPEG4 code - H.264 is best right now, or else xvid or divx. H.264 will produce the best looking video with the smallest size but may take longer to encode.
The GoPro in 50/60 frames progressive is ahead of the standards right now. There isn't really an Official standard that does that framerate in HD. Hence why I recommend streamclip if you just want to clip them down.
For full on video editing I use Corel VideoStudio Pro X. Does everything I need and more and only $120 on line.
For YouTube and Vimeo I usually create a 720P file in DivX format with a reasonable bitrate. Still a couple hundred megs for a few minutes but looks so much better now that everyone has big monitors and broadband.
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
